Automated Testing Suite Overview
Automated Testing Suite (ATS) allows you to execute software test cases using an automated testing tool and then, compares the actual results with the expected or predicted results. In this process, there is no intervention from the user.
ATS for 5G Network Functions
For 5G Network Functions (NFs), ATS is built using Oracle Linux 7-slim as the base image. Jenkins is a part of the ATS image and it provides a GUI interface to the users to test either a single NF or multiple NFs independently in the same environment.
Along with the NF docker images, user are provided with the ATS image, simulator images, and test cases for the specific NF. All these are handed over to the customer as a fully automated suite so that they can directly perform Lab deployment and testing. You can combine it with any other Continuous Integration (CI) pipeline with minimal changes. Since, 5G ATS uses Jenkins as GUI.
