Installing Binding Support Function Cloud Native Services
To install Binding Support Function (BSF) cloud native services, do this:
- Go to the Oracle software delivery Web site:
- Sign in with your user name and password.
- Search for Binding Support Function and select the BSF software pack from the search results.
- Download the BSF package
file. Package is named as follows:
ReleaseName-pkg-Releasenumber.tgzwhere:
ReleaseName is a name which is used to track this installation instance.
Releasenumber is the release number.
For example, ocbsf-pkg-1.4.0.0.0.tgz
- Untar the BSF package file
to get BSF docker image tar file.
tar -xvzf ReleaseName-pkg-Releasenumber.tgzThis command results into
ReleaseName-pkg-Releasenumberdirectory.The directory consists of the following:
- BSF Docker Images File:
ocbsf-images-1.4.0.tar
- Helm File:
ocbsf-1.4.0.tgz
- Readme txt File:
Readme.txt (Contains cksum and md5sum of tarballs)
Load the ocbsf-images-1.4.0.tar file into the Docker system
docker load --input /IMAGE_PATH/ocbsf-images-1.4.0.tar - Verify that the image is
loaded correctly by entering this command:
docker images
- Create a new tag for each
imported image and push the image to the customer docker registry by entering
this command:
docker tag ocbsf/bsf_management_service:1.4.0 CUSTOMER_REPO/bsf_management_service:1.4.0 docker push CUSTOMER_REPO/bsf_management_service:1.4.0 docker tag ocbsf/diam-connector:1.4.0 CUSTOMER_REPO/diam-connector:1.4.0 docker push CUSTOMER_REPO/diam-connector:1.4.0 docker tag ocbsf/diam-gateway:1.4.0 CUSTOMER_REPO/diam-gateway:1.4.0 docker push CUSTOMER_REPO/diam-gateway:1.4.0 docker tag ocbsf/readiness-detector:1.4.0 CUSTOMER_REPO/readiness-detector:1.4.0 docker push CUSTOMER_REPO/readiness-detector:1.4.0 docker tag ocbsf/ocpm_cm_service:1.4.0 CUSTOMER_REPO/ocpm_cm_service:1.4.0 docker push CUSTOMER_REPO/ocpm_cm_service:1.4.0 docker tag ocbsf/nrf_clientservice:1.4.0 CUSTOMER_REPO/nrf_clientservice:1.4.0 docker push CUSTOMER_REPO/nrf_clientservice:1.4.0 docker tag ocbsf/ocpm_config_server:1.4.0 CUSTOMER_REPO/ocpm_config_server:1.4.0 docker push CUSTOMER_REPO/ocpm_config_server:1.4.0 docker tag ocbsf/perf_info:1.4.0 CUSTOMER_REPO/perf_info:1.4.0 docker push CUSTOMER_REPO/perf_info:1.4.0 docker tag ocbsf/app_info:1.4.0 CUSTOMER_REPO/app_info:1.4.0 docker push CUSTOMER_REPO/app_info:1.4.0 docker tag ocbsf/apigateway:1.0.0 CUSTOMER_REPO/ocpm_apigateway:1.4.0 docker push CUSTOMER_REPO/ocpm_apigateway:1.4.0
where:
CUSTOMER_REPO is the docker registry address having Port Number, if registry has port attached.
For OCCNE, copy the package to bastion server and use localhost:5000 as CUSTOMER_REPO to tag the images and push to bastion docker registry.Note:
You may need to configure the Docker certificate before the push command to access customer registry via HTTPS, otherwise, docker push command may fail. - Create the customize ocbsf-custom-values-1.4.0.yaml file with the required input parameters. To customize the file, see Customizing Binding Support Function .
- Go to the helm chart
directory:
cd ocbsf-pkg-1.4.0.0.0
- Install BSF by entering
this command:
helm install HELM_CHART_PATH/bsf-1.4.0.tgz --name BSF_NAME --namespace BSF_NAMESPACE -f CUSTOM_VALUES_YAML_FILE
where:HELM_CHART_PATHis the location of the helm chart extracted from ocbsf-pkg-1.4.0.tgz file
BSF_NAME is the release name used by helm command.
BSF_NAMESPACE is the deployment namespace used by helm command.
CUSTOM_VALUES_YAML_FILE - is the name of the custom values yaml file (including location).
For example:helm install /home/cloud-user/bsf-1.4.0.tgz --name ocbsf --namespace ocbsf -f ocbsf-custom-values-1.4.0.yaml
- Check the deployment status
helm status --name BSF_NAMEwhere:
BSFNAME is the release name used by helm command.
For example:helm status --name ocbsf
You will see the status as DEPLOYED if the deployment has been done successfully.Execute the following command to get status of podswhere:kubectl get pod -n BSF_NAMESPACEBSF_NAMESPACE is the name space in which to create BSF Kubernetes objects. All the BSF microservices are deployed in this kubernetes namespace.
For example:kubectl get pod -n ocbsf
You will see the status as Running for all the nodes if the deployment has been done successfully.
