Installation Preparation
The following table describes the steps to download the CNCC Images and Helm files from OSDC (Oracle Software Delivery Cloud).
Table 2-1 Installation Preparation
| Step Number | Procedure | Description |
| 1. | Download the CNCC package file | Customers are required to download the CNCC
package file from OSDC. The package is named as follows:
cncconsole-pkg-<marketing-release-number>.tgz Example: cncc-pkg-1.0.0.0.0.tgz |
| 2. | Untar the cncc-iam package file | Untar the cncc-iampackage to the specific
repository:
tar -xvf cncconsole-pkg-<marketing-release-number>.tgz The Package file consists of the following:
| 3. | Check the checksums | Check the checksums of tarballs mentioned in
Readme.txt
| 4. | Load the tarball to system | Execute the following command to push the
Docker images to docker repository:
docker load --input <image_file_name.tar> Example docker load --input cncc-images-1.0.0.tar Sample Output: Loaded image: cncc/apigw-configurationinit:1.0.0 Loaded image: cncc/apigw-configurationupdate:1.0.0 Loaded image: cncc/cncc-apigateway:1.0.0 Loaded image: cncc/cncc-cmservice:1.0.0 Loaded image: cncc/cncc-iam:1.0.0 |
| 5. | Push docker files to Docker registry | Execute the following command to push the
docker files to docker registry:
docker tag <image-name>:<image-tag> <docker-repo>/<image-name>:<image-tag> docker push <docker_repo>/<image_name>:<image-tag> |
| 6. | Check if all the images are loaded | Execute the following command to search helm
chart:
docker images |
| 7. | Push helm charts to helm repository | Execute the following command to push the
helm charts to helm repository:
helm push --force <helm_repo> <image_name>.tgz |
