CNC Console Helm Configurable Values
The custom-cncconsole_values.yaml file can also be downloaded from OHC.
cmservice:
dockerRegistry: ocspf-registry.us.oracle.com:5000
image:
tag: helm-tag
# Pull Policy - Possible Values are:- Always, IfNotPresent, Never
pullPolicy: Always
resources:
limits:
cpu: 2
memory: 2Gi
requests:
cpu: 2
memory: 1Gi
deployment:
envManageNF: SCP, NRF, PCF
nodeSelectorEnabled: false
nodeSelectorKey: zone
nodeSelectorValue: app
service:
http:
port: 8442
type: ClusterIP
commonServices:
routes:
ingress-gateway:
global:
# Docker registry name
dockerRegistry: ocspf-registry.us.oracle.com:5000/ocscp
# port on which NRF's API-Gateway service is exposed
# If httpsEnabled is false, this Port would be HTTP/2.0 Port (unsecured)
# If httpsEnabled is true, this Port would be HTTPS/2.0 Port (secured SSL)
publicHttpSignalingPort: 80
publicHttpsSignallingPort: 443
serviceAccountName: ''
#Specify type of service - Possible values are :- ClusterIP, NodePort, LoadBalancer and ExternalName
type: LoadBalancer
#Enable or disable IP Address allocation from Metallb Pool
metalLbIpAllocationEnabled: true
#Address Pool Annotation for Metallb
metalLbIpAllocationAnnotation: "metallb.universe.tf/address-pool: oam"
#If Static load balancer IP needs to be set, then set staticIpAddressEnabled flag to true and provide value for staticIpAddress
#Else random IP will be assigned by the metalLB from its IP Pool
staticIpAddressEnabled: false
staticIpAddress: ""
#If Static node port needs to be set, then set staticNodePortEnabled flag to true and provide value for staticNodePort
#Else random node port will be assigned by K8
staticNodePortEnabled: false
staticHttpNodePort: 30075
staticHttpsNodePort: 30043
image:
# image name
# tag name of image
tag: helm-tag
pullPolicy: Always
initContainersImage:
# inint Containers image name
# tag name of init Container image
tag: helm-tag
pullPolicy: Always
updateContainersImage:
# update Containers image name
# tag name of update Container image
tag: helm-tag
pullPolicy: Always
service:
ssl:
tlsVersion: TLSv1.2
privateKey:
k8SecretName: ingress-secret
k8NameSpace: cncc
rsa:
fileName: rsa_private_key_pkcs1.pem
ecdsa:
fileName: ssl_ecdsa_private_key.pem
certificate:
k8NameSpace: cncc
rsa:
fileName: tmp.cer
ecdsa:
fileName: ssl_ecdsa_certificate.crt
caBundle:
k8NameSpace: cncc
fileName: caroot.cer
keyStorePassword:
k8NameSpace: cncc
fileName: key.txt
trustStorePassword:
k8NameSpace: cncc
fileName: trust.txt
initialAlgorithm: RSA256
ports:
# ContainerPort represents a network port in a single container
containerPort: 8081
containersslPort: 8443
actuatorPort: 9090
log:
level: WARN
readinessProbe:
# tells the kubelet that it should wait second before performing the first probe
initialDelaySeconds: 30
# Number of seconds after which the probe times out
timeoutSeconds: 3
# specifies that the kubelet should perform a liveness probe every xx seconds
periodSeconds: 10
# Minimum consecutive successes for the probe to be considered successful after having failed
successThreshold: 1
# When a Pod starts and the probe fails, Kubernetes will try failureThreshold times before giving up
failureThreshold: 3
livenessProbe:
timeoutSeconds: 3
periodSeconds: 15
successThreshold: 1
failureThreshold: 3
# Resource details
resources:
limits:
cpu: 4
initServiceCpu: 1
updateServiceCpu: 1
memory: 2Gi
requests:
cpu: 4
initServiceCpu: 1
updateServiceCpu: 1
memory: 1Gi
target:
averageCpuUtil: 80
# Nuber of Pods must always be available, even during a disruption.
minAvailable: 1
# Min replicas to scale to maintain an average CPU utilization
minReplicas: 1
# Max replicas to scale to maintain an average CPU utilization
maxReplicas: 5
# enable jagger tracing
jaegerTracingEnabled: false
openTracing :
jaeger:
udpSender:
# udpsender host
host: "occne-tracer-jaeger-agent.occne-infra"
# udpsender port
port: 6831
probabilisticSampler: 0.5
# label to override name of api-gateway micro-service name
fullnameOverride: ingress
# To Initialize SSL related infrastructure in init/update container
initssl: false
#OAUTH CONFIGURATION
oauthValidatorEnabled: false
#Server Configuration for http and https support
enableIncomingHttp: true
enableIncomingHttps: false
enableOutgoingHttps: false
serviceMeshCheck: false
needClientAuth: false
# enable cncc apigateway
# Enabling will this will enable Identity-Access-Management(IAM)
cncoamGatewayEnabled: true
# IAM configuration
# uri should include the IAM Loadbalancer IP and port (e.g. 10.145.22.70:8285)
identityAccessMgt:
#uri: http://10.75.213.121:30024
uri: http://<IP>:<Port>
path: /cncc/auth
realm: cncc
routesConfig:
# Note: Update FQDN and PORT with actual values. If not remove those routes else CNCC will fail to deploy. CNCC requires complete routes and not placeholders.
# Examples for routes
#- id: scpc_configuration
# uri: http://10.75.153.121:31131
# path: /soothsayer/v1/**
#- id: default_configuration
# uri: http://cncc-cmservice.cncc.svc.cluster.local:8442
# path: /**
uri: http://<FQDN>:<PORT>
- id: nrf_configuration
path: /nrf-configuration/v1/**
- id: pcf_configuration
path: /pcfapi/**
rewritePath: "/pcfapi(?<segment>/?.*), $\\{segment}"
- id: default_mapping
uri: http://<helmrelease>-cmservice.<namespace>.<domain>:8442
path: /**
