Creating Database Account on MySQL Database
Create a new database account on MySQL database by executing following command:
CREATE USER
'nefusr'@'%'IDENTIFIED BY 'nefpasswd';
GRANT ALL PRIVILEGES ON *.* TO
'nefusr'@'%';
Login to MySQL console as a new user created above:
mysql -h<MYSQL_HOST> -u
<USERNAME> -p <PASSWORD>
At first login to MySQL console via new user created above,
nefusr -p nefpasswd
Execute the below script to initialize Network Exposure Function databases.
CREATE DATABASE IF NOT EXISTS `ocpm_nef_me`;
CREATE TABLE IF NOT EXISTS `ocpm_nef_me`.`mesubscription` (
`id` int(11) NOT NULL,
`me_subscription` json DEFAULT NULL,
`tltrid` varchar(255) DEFAULT NULL,
PRIMARY KEY (`id`)
) DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
CREATE TABLE IF NOT EXISTS `ocpm_nef_me`. `hibernate_sequence` (
`next_val` bigint(20) DEFAULT NULL
insert into `ocpm_nef_me`. `hibernate_sequence` values (0);
CREATE TABLE IF NOT EXISTS `ocpm_nef_me`.`me_charging` (
`charging_id` varchar(128) NOT NULL,
`charging_request_data` json DEFAULT NULL,
PRIMARY KEY (`charging_id`)
CREATE DATABASE IF NOT EXISTS `ocpm_capif_core`;
CREATE TABLE IF NOT EXISTS `ocpm_capif_core`.`aef_api_profile` (
`apf_id` varchar(255) NOT NULL,
`api_id` varchar(255) NOT NULL,
`aef_profiles` json DEFAULT NULL,
`api_name` varchar(255) DEFAULT NULL,
`description` varchar(255) DEFAULT NULL,
`supported_features` varchar(255) DEFAULT NULL,
PRIMARY KEY (`apf_id`,`api_id`)
CREATE TABLE IF NOT EXISTS `ocpm_capif_core`. `invoker_profile` (
`invoker_id` varchar(255) NOT NULL,
`api_invoker_certificate` varchar(255) DEFAULT NULL,
`api_invoker_public_key` varchar(255) DEFAULT NULL,
`notification_destination` varchar(255) DEFAULT NULL,
`onboarding_secret` varchar(255) DEFAULT NULL,
`request_test_notification` bit(1) DEFAULT NULL,
`request_websocket_uri` bit(1) DEFAULT NULL,
`websocket_uri` varchar(255) DEFAULT NULL,
PRIMARY KEY (`invoker_id`)
CREATE DATABASE IF NOT EXISTS `ocpm_nef_asqos`;
CREATE TABLE IF NOT EXISTS `ocpm_nef_asqos`.`app_session_id_to_sub_id` (
`app_session_id` varchar(128) NOT NULL,
`subsription_id` varchar(128) DEFAULT NULL,
PRIMARY KEY (`app_session_id`)
CREATE TABLE IF NOT EXISTS `ocpm_nef_asqos`.`as_qos_subscription` (
`subscription_id` varchar(128) NOT NULL,
`app_sessionuri` varchar(255) DEFAULT NULL,
`as_qos_subscription` json DEFAULT NULL,
`scs_as_id` varchar(255) DEFAULT NULL,
PRIMARY KEY (`subscription_id`)
CREATE TABLE IF NOT EXISTS `ocpm_nef_asqos`.`scs_as_id_subscription` (
`scs_as_id` varchar(128) NOT NULL,
`sub_id_array` json DEFAULT NULL,
PRIMARY KEY (`scs_as_id`)
CREATE TABLE IF NOT EXISTS `ocpm_nef_asqos`.`asqos_charging` (
CREATE DATABASE IF NOT EXISTS `ocpm_nef_ti`;
CREATE TABLE IF NOT EXISTS `ocpm_nef_ti`.`app_session_id_to_sub_id` (
CREATE TABLE IF NOT EXISTS `ocpm_nef_ti`.`tisubscription` (
`traffic_influ_sub` json DEFAULT NULL,
CREATE TABLE IF NOT EXISTS `ocpm_nef_ti`.`scs_as_id_subscription` (
CREATE TABLE IF NOT EXISTS `ocpm_nef_ti`.`ti_charging` (
CREATE DATABASE IF NOT EXISTS ocpm_nef_ti;
CREATE TABLE IF NOT EXISTS ocpm_nef_ti.ti_data(
scs_as_id varchar(255) NOT NULL,
subscription_id varchar(128) NOT NULL,
traffic_influ_sub json DEFAULT NULL,
af_trans_id varchar(128) UNIQUE,
af_notif_uri varchar(255) DEFAULT NULL,
influence_id varchar(128) NOT NULL UNIQUE,
supi varchar(128) DEFAULT NULL,
inter_group_id varchar(128) DEFAULT NULL,
PRIMARY KEY (subscription_id)
CREATE DATABASE IF NOT EXISTS ocpm_nef_bdt;
CREATE TABLE IF NOT EXISTS ocpm_nef_bdt.nef_bdt
scs_as_id varchar(150) NOT NULL,
bdt_reference_id varchar(255) NOT NULL,
subscription_expiry_ts TIMESTAMP NOT NULL,
bdt JSON NOT NULL,
resource_url varchar(255) NOT NULL,
notification_url varchar(255),
)DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
CREATE DATABASE IF NOT EXISTS `ocpm_config_server_nef`;
CREATE TABLE IF NOT EXISTS `ocpm_config_server_nef`.`topic_info` (
`id` bigint(20) NOT NULL AUTO_INCREMENT,
`description` varchar(255) COLLATE utf8_unicode_ci DEFAULT 'Default Topics.',
`name` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
`modify_date` datetime NOT NULL DEFAULT CURRENT_TIMESTAMP,
`version` int(11) NOT NULL,
PRIMARY KEY (`id`),
UNIQUE KEY `UK_gd6b0a6mdpxc55qbibre2cldc` (`name`)
) AUTO_INCREMENT=3 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
CREATE TABLE IF NOT EXISTS `ocpm_config_server_nef`.`configuration_item` (
`cfg_key` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
`md5sum` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
`cfg_value` mediumtext COLLATE utf8_unicode_ci,
`topic_info_id` bigint(20) NOT NULL,
PRIMARY KEY (`id`),
KEY `FKdue8drxn6acrdt63iacireky1` (`topic_info_id`)
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('policy', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('policySchema', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('policyElement', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('policyParam', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('policygui', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.global.cfg', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.smservice.cfg', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.sessionrule', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.sessionruleprofile', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.authorizeddefaultqos', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.pccrule', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.qosdata', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.chargingdata', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.public.pccruleprofile', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('amservice.system', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('public.matchlist', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pe.serviceTag', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pe.policyTag', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pe.logLevel', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.amservice.app', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('nrfclient.cfg', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('NRF.UDR', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('NRF.BSF', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.userservice.cfg', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('NRF.CHF', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.chfservice', 1);
insert into `ocpm_config_server_nef`.`topic_info` (name, version) values ('pcf.paservice.cfg', 1);
