Verifying Installation
To verify installation, run the following command:
kubectl get svc -n
nefsvc
kubectl get pod -n
nefsvc
If installation is successful, then all pods display in Running/Completed status.
Installation can also be verified via K8S dashboard. The following steps
can be used to do that:
- Under Kubernetes dashboard, click Namespace dropdown list and select NEF namespace
- Click Pods link in the side navigation bar, and then navigate to pod list page
- Check all pods to ensure that all of them are active and running
