Locate Product Documentation on the Oracle Help Center Site
Oracle
Communications customer documentation is available on the web at the Oracle
Help Center site,
http://docs.oracle.com.
You do not have to register to access these documents. Viewing these files
require Adobe Acrobat Reader, which can be downloaded from
http://www.adobe.com.
- Access the Oracle Help Center site at http://docs.oracle.com.
- Click Industries. The Industries Documentation page appears.
- Click Oracle Communications. The Communications page appears. Under the Signaling & Policy heading, click Cloud Native Core. The Cloud Native Core Documentation page appears.
- Select the release number. A list of the documentation set for the selected release displays.
- To download a document to your location, click that document. The selected document loads into the browser. In the left pane, click the Download icon and then the PDF button. The PDF copy of the document appears. Right-click document, select Save as (or similar command based on your browser), and save to a local folder.
