UDM Configuration Parameters
Global Configurations
NUDM-UECM-Service Micro Service
NUDM-UE-Auth-Service Micro Service
NUDM-SDM-Service Micro Service
NUDM-SDM-Notify-Service Micro Service
ausfueauthenticator Micro service
nudm-nrf-client-service Micro Service
ocudm-endpoint Micro service
The UDM micro services have configuration options. The user should be able to configure them via deployment values.yaml
The default value depends on the UDM service. Some of settings default value may change.NAME: is the release name used in helm install command
NAMESPACE: is the namespace used in helm install command
K8S_DOMAIN: is the default kubernetes domain (svc.cluster.local)
Default Helm Release Name:- ocudm
Following tables provide a list of configuration parameters in the Helm file.
These configuration parameters are common to all micro services.
Table 4-1 Global Configurations
| Parameter | Description | Default Value | Range or Possible Values (if applicable) | Notes |
| config.udr.ip | UDR service to connect if not discoverable through NRF | ocudr-endpoint.myudr | Not applicable | This is a fallback option for UDR connectivity |
| config.udr.port | Port to connect to UDR service above | 80 | Valid Port | |
| config.nrfClient.fqdn | NRF Client service fqdn of UDM | ocudm-nudm-nrf-client-service | Not applicable | |
| config.nrfClient.port | NRF Client service port of UDM | 5001 | Valid Port | |
| config.httpRetryCount | Retry count for any http requests towards any client in UDM microservices | 2 | [1 - 4] | |
| config.udmFqdn | FQDN of OCUDM | ocudm-endpoint.myudm.svc.cluster.local | Not applicable | |
| mysql.primary.host | NDB cluster sql primary node IP | udm-db | Valid SQL node IP | |
| mysql.secondary.host | NDB cluster sql secondary node IP | udm-db | Valid SQL node IP | |
| mysql.database | DB name to be used | udmdb | Not applicable | |
| mysql.port | Port used for establishing connections | 3306 | Not applicable | |
| mysql.username | Username for mysql login | changeme | Not applicable | |
| mysql.password | Password for mysql login | changeme | Not applicable |
Table 4-2 NUDM-UECM-Service Micro Service
image.repository |
Full Image Path |
ocudm/nudm_uecm_service |
Not applicable |
image.tag |
Tag of Image |
1.1.0 |
Not applicable |
image.pullPolicy |
This setting will tell if image need to be pulled or not |
Always |
Possible Values - Always IfNotPresent Never |
logging.level.root |
Log Level |
WARN |
Possible Values - WARN INFO DEBUG |
Log level of the nudm-uecm-service pod |
deployment.replicaCount |
Replicas of nudm-uecm-service pod |
2 |
Not applicable |
Number of nudm-uecm-service pods to be maintained by replica set created with deployment |
minReplicas |
Minimum Replicas |
1 |
Not applicable |
Minimum number of pods |
maxReplicas |
Maximum Replicas |
4 |
Not applicable |
Maximum number of pods |
service.http2enabled |
Enabled HTTP2 support flag for rest server |
true |
true/false |
Enable/Disable HTTP2 support for rest server |
service.type |
nudm-uecm-service service type |
ClusterIP |
Possbile Values- ClusterIP NodePort LoadBalancer |
The kubernetes service type for exposing nudm-uecm-service deployment Note: Suggested to be set as ClusterIP (default value) always |
service.port.http |
HTTP port |
5001 |
Valid Port |
The http port to be used in nudm-uecm-service |
service.port.https |
HTTPS port |
5002 |
Valid Port |
The https port to be used for nudm-uecm-service |
service.port.management |
Management port |
9000 |
Valid Port |
The actuator management port to be used for nudm-uecm-service |
resources.request.cpu |
Cpu Allotment for nudm-uecm-service pod |
3 |
Not applicable |
The cpu to be allocated for nudm-uecm-service pod during deployment |
resources.target.averageCpuUtil |
CPU utilization limit for autoscaling |
80 |
Not Applicable |
CPU utilization limit for creating HPA |
Table 4-3 NUDM-UE-Auth-Service Micro Service
| image.repository | Full Image Path | ocudm/nudm_ue_auth_service | Not applicable | |
| image.tag | Tag of Image | 1.1.0 | Not applicable | |
| image.pullPolicy | This setting will tell if image need to be pulled or not | Always | Possible Values - Always IfNotPresent Never | |
| logging.level.root | Log Level | WARN | Possible Values - WARN INFO DEBUG | Log level of nudm-ue-auth-service pod |
| deployment.replicaCount | Replicas of nudm-ue-auth-service pod | 2 | Not applicable | Number of nudm-ue-auth-service pods to be maintained by replica set created with deployment |
| minReplicas | Minimum Replicas | 1 | Not applicable | Minimum number of pods |
| maxReplicas | Maximum Replicas | 4 | Not applicable | Maximum number of pods |
| service.http2enabled | Enabled HTTP2 support flag | true | true/false | Enable/Disable HTTP2 support for rest server |
| service.type | nudm-ue-auth-service service type | ClusterIP | Possbile Values- ClusterIP NodePort LoadBalancer |
The kubernetes service type for exposing nudm-ue-auth-service
deployment
| service.port.http | HTTP port | 5001 | Valid Port | The http port to be used for nudm-ue-auth-service |
| service.port.https | HTTPS port | 5002 | Valid Port | The https port to be used for nudm-ue-auth-service. |
| service.port.management | Management port | 9000 | Valid Port | The actuator management port to be used for nudm-ue-auth-service |
| resources.request.cpu | Cpu Allotment for nudm-ue-auth-service pod | 3 | Not applicable | The cpu to be allocated for nudm-ue-auth-service pod during deployment |
| resources.target.averageCpuUtil | CPU utilization limit for autoscaling | 80 | Not Applicable | CPU utilization limit for creating HPA |
| config.udmAuthService.op | Operator Variant Algorithm Configuration Field on UDM. | cdc202d5123e20f62b6d676ac72cb318 | Hex values
Length: 32 hex digits |
Table 4-4 SDM Micro Service
| deployment.replicaCount | Replicas of nudm-sdm-service pod | 2 | Not applicable | Number of nudm-sdm-service pods to be maintained by replica set created with deployment |
| homeplmnid | Home PLMN id configured on UDM | 12345 | Not Applicable | |
| image.pullPolicy | This setting will tell if image needs to be pulled or not | Always | Possible Values - Always IfNotPresent Never | |
| image.repository | Full Image Path | ocudm/nudm_sdm_service | Not applicable | |
| logging.level.root | Log Level | WARN | Possible Values - WARN INFO DEBUG | Log level of the nudm-sdm-service pod |
| resources.request.cpu | Cpu allotment for nudm-sdm-service pod | 3 | Not applicable | The cpu to be allocated for nudm-sdm-service pod during deployment |
| service.http2enabled | Enabled HTTP2 support flag for rest server | true | true/false | Enable/Disable HTTP2 support for rest server |
| service.port.http | HTTP port | 5001 | Valid Port | The http port to be used in nudm-sdm-service |
| service.port.https | HTTPS port | 5002 | Valid Port | The https port to be used for nudm-sdm-service |
| service.port.management | Management port | 9000 | Valid Port | The actuator management port to be used for nudm-sdm-service |
| service.type | nudm-sdm-service service type | ClusterIP | Possbile Values- ClusterIP NodePort LoadBalancer |
The kubernetes service type for exposing nudm-sdm-service
deployment
| sdmFqdn | SDM FQDN to be used in Location headers in responses sent by SDM service | ocudm-endpoint.myudm | Not Applicable | |
| pendingRetries | Number of retries to be done for subscription failure towards UDR | 5 | Range: 1 - 10 | |
| subscriptionRetryInterval | Frequency in which the subscription retries should be performed towards UDR. | 5 |
Range: 1 - 60 Unit: Seconds |
| sdmNotifyFqdn | This will be used as api root in callbackreference uri in SubscriptionDataSubscription body. | ocudm-endpoint.myudm | Not Applicable |
Table 4-5 NUDM-SDM-Notify-Service Micro Service
| image.repository | Full Image Path | ocudm/nudm_sdm_notify_service | Not applicable | |
| image.pullPolicy | This setting tells if image need to be pulled or not | Always | Possible Values - Always IfNotPresent Never | |
| logging.level.root | Log Level | WARN | Possible Values - WARN INFO DEBUG | Log level of the nudm-sdm-notify-service pod |
Replicas of nudm-sdm-notify-service pod |
Number of nudm-sdm-notify-service pods to be maintained by replica set created with deployment |
The kubernetes service type for exposing nudm-sdm-notify-service deployment Note: Suggested to be set as ClusterIP (default value) always |
The http port to be used in nudm-sdm-notify-service |
The https port to be used for nudm-sdm-notify-service |
The actuator management port to be used for nudm-sdm-notify-service |
Cpu Allotment for nudm-sdm-notify-service pod |
The cpu to allocated for nudm-sdm-notify-service pod during deployment |
| notifyRetryCount | Number of retries to be done for notification failure towards AMF | 1 | Range: 1 - 10 | |
| notifyRetryInterval |
Frequency in which the notification retries should be performed towards AMF. |
5 |
Table 4-6 ausfueauthenticator Micro Service
| image.repository | Full Image Path | ocudm | Not applicable | |
| image.name | Full name | nudm_ausf_ueauth_service | Not applicable | |
| loglevel | Log Level | WARN | Possible Values - WARN INFO DEBUG | Log level of the ausfueauthenticator pod |
Replicas of ausfueauthenticator pod |
Number of ausfueauthenticator pods to be maintained by replica set created with deployment |
| service.type | ausfueauthenticator service type | ClusterIP |
The kubernetes service type for exposing ausfueauthenticator deployment Note: Suggested to be set as ClusterIP (default value) always |
The http port to be used in ausfueauthenticator service |
The https port to be used for ausfueauthenticator service |
The actuator management port to be used for ausfueauthenticator service |
Cpu Allotment for ausfueauthenticator pod |
The cpu to allocated for ausfueauthenticator pod during deployment |
| servingNetworkNameList | List of serving network names by the AUSF node |
5G: mnc100.mcc101.3gppnetwork.org ,5G: mnc101.mcc102.3gppnetwork.org |
Not Applicable | |
| configuredUdm | Enable usage of the configured UDM in values | true | true/false | |
| UdmHost | The configured UDM host fqdn | ocudm-nudm-ue-auth-service | Not Applicable | |
| UdmPort | Port to connect to the UDM pod | 5001 | Valid Port | |
| auditDuration | 3600000 | |||
| expiryDuration | 300000 | |||
| unexpectedAuthTypeNotify | true | true/false | ||
| nrfHost | The NRF client service host details running as part of this UDM AUSF helm deployment | ocudm-nudm-nrf-client-service | Not Applicable | |
| nrfPort | The port to be used to connect to NRF client service | 5001 |
Valid Port |
Table 4-7 nudm-nrf-client-service Micro Service
| host.registrationbaseurl | NRF url for registration | http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-nfm/v1/nf-instances | Not applicable | |
| host.subscriptionbaseurl | NRF url for registration | http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-nfm/v1/subscriptions | ||
| host.discoverybaseurl | NRF url for registration | http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-disc/v1/nf-instances | ||
| host.notifybaseurl | NRF url for registration | http://ocudm-nudm-nrf-client-service.myudm.svc.cluster.local:5001/nnrf-client/v1/notify | ||
| host.notificationbaseurl | NRF url for registration | http://ocudm-nudm-nrf-client-service.myudm.svc.cluster.local/nnrf-client/v1/notify | ||
| host.proxy.ssl | SSL flag | false | true/false | SSL flag to enable SSL with udr nrf client pod |
| logging.level.root | Log Level | WARN | Possible Values - WARN INFO DEBUG | Log level of the UDM nrf client pod |
| image.repository | Full Image Path | ocudm/nrf_client_service | Not applicable | |
| heartBeatTimer | Heart beat timer | 90 | Unit: Seconds | |
| udmgroupId | Group ID of UDM | udm-1 | Not applicable | |
| ausfgroupId | Group ID of AUSF | ausf-1 | ||
| capacityMultiplier | Capacity of UDM | 500 | Not applicable | Capacity multiplier of UDM based on number of UDM pods running |
| supirange | Supi Range supported with UDM | [{\"start\": \"10000000000\", \"end\": \"20000000000\"}] | Valid ue range | |
| gpsiRanges | gpsi Range supported with UDM | [{\"start\": \"10000000000\", \"end\": \"20000000000\"}] | Valid ue range | |
| externalGroupIdentifiersRanges |
External group identifier range supported with UDM |
| priority | Priority to be sent in registration request | 10 | Not applicable | |
| routingIndicators | Routing Indicators send in NRF registration request | [\"00\"] | Not applicable | |
| udmAllowedNfs | UDM allowed NF type to be sent in NRF registration request | AMF,CUSTOM_ORACLE_SCP,SMF,AUSF | Any valid NF name as per spec | |
| ausfAllowedNfs |
AUSF allowed NF type to be sent in NRF registration request |
AMF,CUSTOM_ORACLE_SCP | Any valid NF name as per spec | |
| plmnList | PLMN list used during registration | [{\"mnc\": \"14\", \"mcc\": \"310\"}] | Valid MCC and MNC values | |
| masterIp | NF service ipv4 address to be used during UDM/AUSF registration | 10.0.0.0 | Valid IP address | |
| authFqdn | FQDN for auth service to be registered with NRF | ocudm-ausfueauthenticator.myudm.svc.cluster.local | Not Applicable | |
| sdmFqdn | FQDN for sdm service to be registered with NRF | ocudm-nudm-sdm-service.myudm.svc.cluster.local | Not Applicable | |
| sdmNotifyFqdn | FQDN for sdm notify service to be registered with NRF | ocudm-nudm-sdm-notify-service.myudm.svc.cluster.local | Not Applicable | |
| uecmFqdn | FQDN for uecm service to be registered with NRF | ocudm-nudm-uecm-service.myudm.svc.cluster.local | Not Applicable | |
| ueauFqdn | FQDN for ueau service to be registered with NRF | ocudm-nudm-ue-auth-service.myudm.svc.cluster.local | Not Applicable | |
| locality | Operator defined information about the location of the NF instance (e.g. geographic location, data center) | West0 | Not Applicable | |
| endpointLabelSelector | Label selector used for ocudm endpoint | ocudm-endpoint | Not Applicable | |
| livenessProbeUrludm | URL used by nrf-client-service to check liveness probe of other udm microservice pods. This includes apigateway and excludes AUSF pod | http://ocudm-nudm-uecm-service.myudm.svc.cluster.local:9000/actuator/health,http://ocudm-nudm-ue-auth-service.myudm.svc.cluster.local:9000/actuator/health,http://ocudm-nudm-sdm-service.myudm.svc.cluster.local:9000/actuator/health,http://ocudm-nudm-sdm-notify-service.myudm.svc.cluster.local:9000/actuator/health | Not Applicable | Be cautious in updating this value. Should consider namespace used for udm deployment and name resolution setting in k8s |
| livenessProbeUrlausf | URL used by nrf-client-service to check liveness probe of other ausf microservice pod along with apigateway. | http://ocudm-ausfueauthenticator.myudm.svc.cluster.local:9000/actuator/health | Not Applicable | Be cautious in updating this value. Should consider namespace used for udm deployment and name resolution setting in k8s. |
| fqdn | UDM FQDN | ocudm-endpoint.myudm.svc.cluster.local | Not Applicable |
FQDN to used for registering in NRF for other NFs to connect
to UDM.
Note: Be cautious in updating this value. Should consider namespace used for udm deployment and name resolution setting in k8s. |
Table 4-8 OCUDM-Endpoint Micro Service
| fullnameOverride | Name to be used for deployment | ocudm-endpoint | Not applicable | |
| global.type | ocudm-endpoint service type | LoadBalancer |
global. dockerRegistry |
Docker registry to pull image |
docker-registry.udr.us.oracle.com :5000/ocudm |
Not applicable | |
global. staticNodePortEnabled |
assign static pre-defined port to api-gateway service | false | true/false | |
global. staticHttpNodePort |
static http node port value | 30075 | 30000-32767 | |
global. staticHttpsNodePort |
static https node port value | 30043 | 30000-32767 | |
global. service.metalLbIpAllocationEnabled |
Enable or disable Address Pool for Metallb | true | true/false | |
| global.metalLbIpAllocationAnnotation | Address Pool for Metallb |
" metallb.universe.tf/address-pool: signaling" |
Not applicable | |
| image.name | Docker image name | ocingress_gateway | Not applicable | |
| image.tag | Image version tag | 1.5.0 | Not applicable | |
| resources.requests.cpu | Cpu request for ocudm-endpoint pod | 3 | Not applicable | |
| resources.requests.memory | Memory request for ocudm-endpoint pod | 2G | Not applicable | |
| resources.limits.cpu | Cpu limit for ocudm-endpoint pod | 4 | Not applicable | |
| resources.limits.memory | Memory limit for ocudm-endpoint pod | 2G | Not applicable | |
| resources.target.averageCpuUtil | CPU utilization limit for auto scaling | 80 | Not applicable | |
| log.level | Logging level | INFO | INFO/DEBUG/WARN | |
| initssl | Initialize SSL framework | false | Not Applicable | |
| oauthValidatorEnabled | OAUTH Configuration | false | Not Applicable | |
| enableIncomingHttp | enable/disable incoming HTTP packets | true | true/false | |
| enableIncomingHttps | enable/disable incoming HTTPS packets | false | true/false | |
| enableOutgoingHttps | enable/disable outgoing HTTPS packets | false | true/false | |
| maxConnectionsQueuedPerDestination | Queue Size of api-gateway | 5000 | Not Applicable | |
| maxConnectionsPerIp | Connections from api-gateway to other microServices | 10 | Not Applicable | |
| routesConfig | Routes configured to connect to different micro services of UDM | - id: uecm_mapping_http uri: http://{{ .Release.Name
}}-nudm-uecm-service:5001 path: /nudm-uecm/** - id: ue_auth_mapping_http uri:
http://{{ .Release.Name }}-nudm-ue-auth-service:5001 path: /nudm-ueau/** - id:
sdm_mapping_http uri: http://{{ .Release.Name }}-nudm-sdm-service
:5001 path: /nudm-sdm/** - id: sdm_notify_mapping_http uri: http://{{ .Release.Name }}-nudm-sdm-notify-service:5001 path: /nudm-sdm-notify/** - id: ausf_mapping_http uri: http://{{ .Release.Name }}-ausfueauthenticator:5001 path: /nausf-auth/** |
Not Applicable |
