Customizing Unified Data Repository
The Unified Data Repository deployment could be customized by overriding the default values of various configurable parameters.
In Deploying Cloud Native Unified Data Repository, the MySQL host is customized.
A values.yaml file could be prepared by hand to customize the parameters.
Following is an example of Unified Data Repository customization file.
# Copyright 2019 (C), Oracle and/or its affiliates. All rights reserved.
global:
mysql:
dbServiceName: "udrdbservice" #This is a read only parameter. Use the default value.
port: "3306"
dbname: "udrdb"
dsusername: "udruser"
dspassword: "udrpasswd"
udrdbservice:
primaryhost: "10.75.173.213"
secondaryhost: "10.75.173.217"
port: "3306"
targetPort: "3306"
jaeger:
service:
port: 9411
hikari:
poolsize: "25"
dbenc:
passphrase: "My secret passphrase"
shavalue: 256
nudr-drservice:
image:
repository: udr-dev-bastion-1:5000/ocudr/nudr_datarepository_service
tag: 1.5.0
pullPolicy: IfNotPresent
service:
http2enabled: "true"
type: ClusterIP
port:
http: 5001
https: 5002
management: 9000
notify:
port:
http: 5001
https: 5002
deployment:
replicaCount: 1
logging:
level:
root: "WARN"
subscriber:
autocreate: "true"
validate:
smdata: "true"
resources:
limits:
cpu: 3
memory: 4Gi
requests:
cpu: 3
memory: 4Gi
target:
averageCpuUtil: 80
minReplicas: 1
maxReplicas: 4
nudr-notify-service:
image:
repository: udr-dev-bastion-1:5000/ocudr/nudr_notify_service
tag: 1.5.0
service:
type: ClusterIP
port:
http: 5001
https: 5002
management: 9000
deployment:
replicaCount: 1
notification:
retrycount: "3"
retryinterval: "5"
retryerrorcodes: "400,429,500,503"
logging:
level:
root: "WARN"
resources:
limits:
cpu: 3
memory: 4Gi
requests:
cpu: 3
memory: 4Gi
target:
averageCpuUtil: 80
minReplicas: 1
maxReplicas: 4
nudr-nrf-client-service:
host:
baseurl: "http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-nfm/v1/nf-instances"
proxy:
ssl: "false"
logging:
level:
root: "WARN"
image:
repository: udr-dev-bastion-1:5000/ocudr/nrf_client_service
tag: 1.5.0
heartBeatTimer: "90"
groupId: "udr-1"
capacityMultiplier: "500"
supirange: "[{\"start\": \"10000000000\", \"end\": \"20000000000\"}]"
priority: "10"
# The below 2 configuration will change based on site k8s name resolution settings, Also note the changes with namespace used for udr installation
livenessProbeUrl: "http://nudr-notify-service.myudr.svc.cluster.local:9000/actuator/health,http://nudr-drservice.myudr.svc.cluster.local:9000/actuator/health,http://ocudr-endpoint.myudr.svc.cluster.local:9000/actuator/health"
fqdn: "ocudr-endpoint.myudr.svc.cluster.local"
ingress-gateway:
global:
# Docker registry name
dockerRegistry: udr-dev-bastion-1:5000/ocudr
# Specify type of service - Possible values are :- ClusterIP, NodePort, LoadBalancer and ExternalName
type: LoadBalancer
# Enable or disable IP Address allocation from Metallb Pool
metalLbIpAllocationEnabled: true
# Address Pool Annotation for Metallb
metalLbIpAllocationAnnotation: "metallb.universe.tf/address-pool: signaling"
# If Static node port needs to be set, then set staticNodePortEnabled flag to true and provide value for staticNodePort
# # Else random node port will be assigned by K8
staticNodePortEnabled: false
staticHttpNodePort: 30075
staticHttpsNodePort: 30043
image:
# image name
# tag name of image
tag: 1.5.0
# Pull Policy - Possible Values are:- Always, IfNotPresent, Never
pullPolicy: Always
initContainersImage:
# inint Containers image name
# tag name of init Container image
tag: 0.1.0
pullPolicy: Always
updateContainersImage:
# update Containers image name
# tag name of update Container image
tag: 0.1.0
pullPolicy: Always
service:
ssl:
tlsVersion: TLSv1.2
privateKey:
k8SecretName: ocegress-secret
k8NameSpace: ocegress
rsa:
fileName: rsa_private_key_pkcs1.pem
ecdsa:
fileName: ssl_ecdsa_private_key.pem
certificate:
rsa:
fileName: tmp.cer
ecdsa:
fileName: ssl_ecdsa_certificate.crt
caBundle:
fileName: caroot.cer
keyStorePassword:
fileName: key.txt
trustStorePassword:
fileName: trust.txt
initialAlgorithm: RSA256
# Resource details
resources:
limits:
cpu: 3
memory: 4Gi
requests:
cpu: 3
memory: 4Gi
target:
averageCpuUtil: 80
log:
level: INFO
# label to override name of api-gateway micro-service name
fullnameOverride: endpoint
# To Initialize SSL related infrastructure in init/update container
initssl: false
# Cipher suites to be enabled on server side
ciphersuites:
- TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
- TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_DHE_RSA_WITH_AES_256_CCM
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
#OAUTH CONFIGURATION
oauthValidatorEnabled: false
nfType: SMF
nfInstanceId: 6faf1bbc-6e4a-4454-a507-a14ef8e1bc11
producerScope: nsmf-pdusession,nsmf-event-exposure
allowedClockSkewSeconds: 0
nrfPublicKeyKubeSecret: nrfpublickeysecret
nrfPublicKeyKubeNamespace: ingress
validationType: strict
producerPlmnMNC: 123
producerPlmnMCC: 346
#Server Configuration for http and https support
#Server side http support
enableIncomingHttp: true
#Server side https support
enableIncomingHttps: false
#Client side https support
enableOutgoingHttps: false
maxConnectionsQueuedPerDestination: 5000
maxConnectionsPerIp: 10
#Service Mesh (Istio) to take care of load-balancing
serviceMeshCheck: false
# configuring routes
routesConfig:
- id: traffic_mapping_http
uri: http://{{ .Release.Name }}-nudr-drservice:5001
path: /nudr-dr/**
- id: traffic_mapping_http_prov
path: /nudr-dr-prov/**
- id: traffic_mapping_http_mgmt
path: /nudr-dr-mgm/**
- id: traffic_mapping_http_udsf
path: /nudsf-dr/**
- id: traffic_mapping_http_group
path: /nudr-group-id-map/**
- id: traffic_mapping_http_group_prov
path: /nudr-group-id-map-prov/**
