Creating Private Keys and Certificates for Ingress Gateway and Egress Gateway
This chapter describes how to create private keys and certificates in PCF.
To create private keys and certificates:
- Generate RSA private key
by executing the following command:
openssl req -x509 -nodes -sha256 -days 365 -newkey rsa:2048 -keyout rsa_private_key -out rsa_certificate.crt
- Convert private key to
.pem format by executing the following command:
openssl rsa -in rsa_private_key -outform PEM -out rsa_private_key_pkcs1.pem
- Generate certificate using
the private key by executing the following command:
openssl req -new -key rsa_private_key -out ocegress.csr -config ssl.conf
The ssl.conf can be used to configure default entries along with storage area network (SAN) details for your certificate.A sample of the ssl.conf is provided below:#ssl.conf [ req ] default_bits = 4096 distinguished_name = req_distinguished_name req_extensions = req_ext [ req_distinguished_name ] countryName = Country Name (2 letter code) countryName_default = IN stateOrProvinceName = State or Province Name (full name) stateOrProvinceName_default = Karnataka localityName = Locality Name (eg, city) localityName_default = Bangalore organizationName = Organization Name (eg, company) organizationName_default = Oracle commonName = Common Name (e.g. server FQDN or YOUR name) commonName_max = 64 commonName_default = localhost [ req_ext ] subjectAltName = @alt_names [alt_names] IP = 127.0.0.1 DNS.1 = localhost
- Create root certificate
authority (CA) by executing the following set of commands:
openssl req -new -keyout cakey.pem -out careq.pem
openssl x509 -signkey cakey.pem -req -days 3650 -in careq.pem -out caroot.cer -extensions v3_ca
echo 1234 > serial.txt
- Sign the server
certificate with root CA private key by executing the following command:
openssl x509 -CA caroot.cer -CAkey cakey.pem -CAserial serial.txt -req -in ocegress.csr -out ocegress.cer -days 365 -extfile ssl.conf -extensions req_ext
The ssl.conf file must be reused, as SAN contents is not packaged when signing. - Create key.txt by entering any password.
- Create trust.txt by entering any password.
Creating a Secret
You should create a secret for database access before deploying PCF.To create a secret:
- Create namespace by
kubectl create ns NameSpacewhere:namespace is the deployment namespace used by the helm command.
- Generate secret out of the
keys and certificates by executing the following command:
kubectl create secret generic k8SecretName --from-file=rsa_private_key_pkcs1.pem --from-file=trust.txt --from-file=key.txt --from-file=ocegress.cer --from-file=caroot.cer -n k8NameSpace
where:k8NameSpace is the deployment namespace used by the helm command.
k8SecretName is the name of secret generated.
For example:kubectl create secret generic pcf-gateway-secret --from-file=rsa_private_key_pkcs1.pem --from-file=trust.txt --from-file=key.txt --from-file=ocegress.cer --from-file=caroot.cer -n pcf
