Cloning a Repository
This topic explains how to clone a repository from within Code Editor.
You can clone a repository from within Code Editor.
To clone a repository:
- Open the Command Palette by pressing Control-Shift-P
- Type
git cloneand pressEnter - Type or paste the name of the repository that you want to clone and press Enter. A file dialog appears.
- Select the folder that you want to use to clone the repository and then click the Select Repository Location button.
- A dialog box will prompt you to either open the repository or to add it to the current workspace.
- You've now cloned a repository and can edit files using Code Editor.
