Deleting a Block Volume from a Roving Edge Infrastructure Device
Describes how to delete a block volume from your Roving Edge Infrastructure device.
The volume can't have an active connection to an instance.
All data on the volume is permanently lost when the volume is deleted.
Select a State from the list to limit the block volumes displayed to that state.
Select the block volume that you want to delete. The block volume's Details page appears.
Select Terminate.
Confirm the deletion when prompted.
Use the oci bv volume delete command and required parameters to delete a block volume from your Roving Edge Infrastructure devices:
oci bv volume delete --volume-id volume_ocid [OPTIONS]Refer to your Roving Edge Infrastructure device's CLI help for a list of parameters available for this command. See Accessing Command Line Interface Help.
For CLI setup information on your Roving Edge Infrastructure device, see Using the Command Line Interface.
Run the DeleteVolume operation to delete a block volume from your Roving Edge Infrastructure devices.
