Testing a Connection
Test a data asset connection in Data Catalog.
    1. On the Home tab, click Data Assets to access the Data Assets tab.
    2. In the Data Assets list, click the data asset you want to edit. The data asset details tab displays.
    3. In the Summary tab, under Connection Information, click the Actions menu for the connection you want to test and select Test Connection.
    The connection is tested and a notification displays indicating if the test connection is successful.
  • Use the test command and required parameters to test a connection:
    oci data-catalog connection test [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the CLI Command Reference.
  • Run the TestConnection operation to test a connection.
