Editing the Custom Properties of a Term
Update the custom properties of a term.
- On the glossary details page, in the Hierarchy pane, select the term that you want to edit.
- In the Custom Properties section of the Summary tab, click Edit. The Edit Custom Properties panel opens as an overlay.
- Make the required changes and click Save Changes.
Use the update command and required parameters to edit the properties of a term:
oci data-catalog term update [OPTIONS]For a complete list of flags and variable options for CLI commands, see the CLI Command Reference.
This task isn't available in the API.
