Using the Home Tab
The Home tab of a data catalog instance has four sections.
2. Tiles
The following tiles in the home page let you use your data catalog effectively:
  • Quick Actions: Provides links to frequently performed actions in a data catalog instance.
  • Data Assets by Type: Displays a pie chart showing the number and type of data assets created in the data catalog instance.
  • Popular Data Catalog Tags: Displays all the tags created and applied to data objects. Click a tag to view a list of all the data objects that are linked to the tag.
  • Learn: Displays links to the Data Catalog service guide, Data Catalog REST API reference, Data Catalog videos, tutorials, and release notes.
  • Recently Updated: Displays the data catalog objects that were recently updated.
Note
After creating a data catalog instance, when you access the Home tab for the first time, the following tiles appear:
4. Tab Management
The open tab and tab settings icons are available to you from any page in a data catalog instance.
Click the open tab (plus icon) to open a new tab.
Click the tab settings (down arrowhead icon) to view all open tabs, return to the Home tab, or close all tabs.
