Application Parameters
If the Spark application requires one or more parameters at run time, then Data Flow lets you provide the parameter name and default value when you create the application.
${MyParameter}After you provide the
            parameter name in the Arguments field, a Parameters section with two new
            fields appears below it. The fields are Name, and Default Value. The
                Name field isn't editable, and contains the name of your parameter. The
                Default Value field is editable, and you can enter a default value for the
            parameter. The default value can be over-ridden at execution time.Parameter1, Parameter2, and
                Parameter3, with values of Value1,
                Value2, and Value3, and enter them as follows:
            ${Parameter1}${Parameter2} ${Parameter3}then the resulting
            argument provided to Data Flow, has only two
            values:Value1Value2 Value3which might not be what you want.Each parameter has its own Name and Default Value fields.
For SQL applications, the parameter entry doesn't use the ${MyParameter} format.
            Instead, the Parameters section with a single Name text field and its
            corresponding Value field are present. Enter the name of the parameter and the
            default value in the corresponding field. If you need to add several parameters, click
            the +Add Parameters button.
Application Parameters when Running Applications
Application Parameters let you reuse your Data Flow Applications in various different ways. See Run Applications for more information.
