Listing Runs in Data Flow
How to view Runs and their details in Data Flow.
    1. Open the navigation menu, and select Analytics and AI. Under Data Lake select Data Flow.
    2. In the left-side menu, select Runs.
    3. Under List scope, select the compartment that contains the runs that you want to list.
      The runs are displayed in a table, showing the name, language, state, owner, when each was created, the duration of each, the total OCPU, the amount of data read, and how much data was written. From the actions menu several actions are available on each Run.
    Search, Sort, Or Filter Runs In Data Flow
    You can filter, search, and sort the list of Runs in several ways.
    In the left-hand side menu, go to the Filters section. You can filter on the state of the Runs and the language used. You can also set a date range during which Runs were created using the Created start date and Created end date fields. You can filter by owner, and you can enter all or part of a Run run name in the Name prefixfield. You can choose to filter on one, or some, or all of these options. You can clear all these fields to remove the filters.
    If you have applied tags to the Runs, you can filter on these tags in the Tag filters section. You can clear these tag filters.
    These filtering options also let you to search for a Run if you can't remember the specifics of it; for example, you know it was created last week, but can't remember exactly when.
    You can sort the list of Runs by Created date, either ascending or descending.
  • Use the list command and required parameters to view the runs in a specific compartment:
    oci data-flow private-endpoint delete [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the CLI Command Reference.
  • Run the ListRuns operation to list all the runs of an application in a specific compartment.
