Attaching a Private Endpoint
You attach a private endpoint to a Data Flow Application to enable the Application to run using the configured private network.
You can attach only one private endpoint to an Application, but you can attach a private endpoint to many Applications. Before you attach a private endpoint to an Application, you must create a private endpoint.
- Follow these steps in the Console to attach a private endpoint. - On the Data Flow page, in the left-side menu, select Applications. If you need help finding the Data Flow page, see Listing Applications.
- Select the name of the Application.
- On the Application details page, select Edit.
- Scroll to the bottom of the Edit application panel, and select Show advanced options.
- In the Choose network access section, select Secure access to private subnet.
- Select the private endpoint that you want to attach to the Application. Select Change compartment if it's in a different compartment to the Application.
- Select Save changes.
- This task is not available in the CLI.
- This task is not available in the API.
