Moving a Private Endpoint
Move a private endpoint resource in Data Flow from the compartment you created it in to a different compartment.
Use the change-compartment command and required parameters to move a private endpoint to a different compartment:
oci service-name command-name --required-param-name variable-name ... [OPTIONS]For a complete list of flags and variable options for CLI commands, see the CLI Command Reference.
Run the ChangePrivateEndpointCompartment operation to move a private endpoint to a different compartment.
