Deleting a SQL Endpoint
You can delete a Data Flow SQL endpoint.
- Use the Data Flow SQL Endpoints Delete CLI command and required parameters to delete a SQL Endpoint: - oci data-flow sql-endpoint delete [OPTIONS]- For a complete list of parameters and values for CLI commands, see the CLI Command Reference.
- Run the Data Flow SQL Endpoints Delete API operation to delete a SQL Endpoint.
