Creating a Project (Blank or with Samples)
Create a project with or without sample data flows in a Data Integration workspace.
To create a project with samples, you're prompted to select a bucket in OCI Object Storage. Ensure that you have already created an Object Storage bucket and the required policies for Data Integration to access buckets and stage data. See the policies for Object Storage.
- The details page of the new project opens. - If you selected Create sample artifacts, the service creates the v1_0 folder in the new project, and displays that folder's details page. Select Data flows to explore the sample data flows that are created for you.
- Use the oci data-integration project create command and required parameters to create a project: - oci data-integration project create [OPTIONS]- For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
- Run the CreateProject operation to create a project.
