Microsoft Azure SQL Database Data Asset Properties
You can use a secret for the password.
See OCI Vault Secrets and Oracle Wallets.
To create a data asset that connects to an Azure SQL database source, complete the following properties and connection details.
| Field | Description |
| Properties | |
| Name | Enter a name for the data asset. |
| Identifier | The identifier is a system-generated value based on the name. You can change the identifier value, but after you create and save, you cannot update the identifier. |
| Description | (Optional) Add a description. |
| Type | The field shows the data source type that you selected in the Select data asset type panel (as described in Creating a Data Asset). Data Integration displays the data asset property fields and default connection fields based on this type. |
| Host |
Enter the IP address of the host. |
| Port |
Enter the port number to use. |
| Database name |
(Optional) Enter the database name. |
| Enable SSL and Validate server certificate |
Select the Enable SSL checkbox if you want SSL-based authentication. Then optionally select the Validate server certificate checkbox to validate the server certificate. |
| Default connection information | |
| Name | Enter a name for the default connection. |
| Username |
Enter the user name. |
| Use vault secret OCID | If you use a secret in Oracle Cloud Infrastructure Vault to store the password, select this option. The following field appears:
| Use password |
If you select this option, enter the password in the Password field. |
| (Optional) Test connection | |
| Test connection | After you complete all the required fields, select Test connection to ensure that the data asset details have been entered correctly and the connection can be established. A success message appears if the test is successful. If the test fails with an error message, review the connection settings and try again. |
