Deleting a Connection
Delete a connection in a data asset in a Data Integration workspace. After you delete a connection, it cannot be restored.
The connection can't be deleted if it's the specified default connection or the only connection in the data asset.
    1. On the Data assets list page, select the name of the data asset that you want to work with. If you need help finding the list page or the data asset, see Listing Data Assets.
    2. On the data asset details page, Connections list, find the connection that you want to delete.
    3. From the Actions menu (three dots) of the connection, select Delete.
      The Delete action is unavailable if the connection is the specified default connection or the only connection in the data asset.
    4. In the Delete connection dialog box, confirm that you want to delete this connection, and then select Delete.
      A notification appears informing you that the connection is deleted successfully.
  • Use the oci data-integration connection delete command and required parameters to delete a connection:
    oci data-integration connection delete [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
  • Run the DeleteConnection operation to delete a connection.
