Editing a Connection
Edit a data asset's connection in a Data Integration workspace.
- Note
Support for using passwords will be deprecated soon. We recommend that you use the OCI Vault option. For information, see OCI Vault Secrets and Oracle Wallets. Use the oci data-integration connection update command and required parameters to update a connection:
oci data-integration connection update [OPTIONS]For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
Run the UpdateConnection operation to update a connection.
