Exporting a Project
Export a project from a Data Integration workspace to an Object Storage bucket.
By default, Data Integration includes referenced objects such as data assets in an export request.
Before exporting a project, see Considerations When Using Export and Import for information about objects that have references across folders in a project.
To export a project, specify the details for the export project zip file such as the file name and the location of the bucket. Ensure that you have an Object Storage bucket and the relevant permissions and IAM policies as described in Required Setup and Policies.
- Use the oci data-integration export-request create command and required parameters to export a project: - oci data-integration export-request create [OPTIONS]- For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
- Run the CreateExportRequest operation with the appropriate request details to export the project.
