Monitoring an Application
View run information for an application within a specific time period.
  1. On the Applications list page, select the compartment that contains the application. If you need help finding the list page, see Listing Applications.
  2. In the list of applications, select the name of the application that you want to monitor.
  3. On the application details page, select Monitor application.
    A panel appears, showing the following statuses:
    • Running: Number of task runs that are still in progress.
    • Queued: Number of task runs that are waiting for execution. The status transitions to Running when resources are available.
    • Not started: Number of task runs that are started but not yet submitted to the execution engine.
    • Terminating: Number of task runs that are in the process of being stopped (terminated).
    • Success: Number of task runs that have completed successfully.
    • Failed: Number of task runs that have failed.
    • Terminated: Number of task runs that are stopped (terminated).
  4. In the Monitor application panel, use the calendar menus to specify a date and time range.
    After selecting a date and time range, the number of task runs that are initiated within the specified time period appears under Total runs. The total number of task runs is the sum of task runs with the statuses shown.
    Tip
    Data Integration doesn't refresh the numbers on the page automatically. To see updated numbers, close the Monitor application panel. On the application details page, select Monitor application and then select the date and time range again.
