Running a Task
Manually run a published task from an application in Data Integration.
To schedule a task for automated runs, see Scheduling Published Tasks to Run.
If the task uses parameters, a panel opens to let you edit the parameter values for the run.
If you're running a pipeline that includes tasks that are configured to run in the OCI
Data Flow service, use the following format if editing the default parameter values for OCI_DF_LOG_BUCKET
and OCI_DF_ARTIFACT_BUCKET
: oci://<bucket-name>@<tenancy-name>
A run entry is created in the Runs section of the application details page. See Listing Task Runs. To manually terminate a run, see Terminating a Task Run.
Use the oci data-integration task-run create command and required parameters to create a task run for a published task in an application in Data Integration:
oci data-integration task-run create [OPTIONS]
Rerunning a task uses the same command.
For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
Run the CreateTaskRun operation to create a task run for a published task in an application in Data Integration.
Rerunning a task uses the same operation.
