Starting a Workspace
Restart a Data Integration workspace that's stopped. When you start a stopped workspace, you acknowledge that Oracle can continue to bill you for workspace use.
    1. On the Data Integration Workspaces list page, find the workspace that you want to start. If you need help finding the list page, see Accessing Workspaces.
    2. From the Actions menu (Actions menu) of a stopped workspace, select Start.
    3. Select Start
    You can access the workspace when the status changes to Active.
  • Use the oci data-integration workspace start command and required parameters to start a stopped workspace:
    oci data-integration workspace start [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
  • Run the StartWorkspace operation to start a stopped workspace.
