Model Deployment Metrics
Learn about how to use metrics for model deployments.
Metrics are automatically available for any Data Science model deployments that you create in the oci_datascience_modeldeploy namespace. You don't need to enable monitoring on OCI resources to get these metrics.
Data Science model deployments metrics include these dimensions:
resourceId
The OCID of the model deployment.
statusCode
The HTTP response status code.
result
Result of response:
  • Success
  • Failure
statusFamily
Status family of result:
  • Success: 2XX
  • Failure: 4XX and 5XX
instanceId
The ID of instance.
networkType
Types of network:
  • BytesIn: Network receive throughput
  • BytesOut: Network transmission throughput
modelOcid
The OCID of the model with in the deployed model group. You can filter out the model-specific predict request logs based on the modelOcid at the model router.
Metric Names Display Name Unit Description Dimensions
PredictRequestCount Predict Request Count Count Number of predict requests.
resourceId
PredictResponse Predict Response Success Rate Percentage Predict response success rate. It's calculated based on the number of successful predict requests out of total number of predict requests.
resourceId
statusCode
result
statusFamily
Predict Response Status Count Predict response result and status code.
PredictLatency Predict Latency Milliseconds Latency of predict calls.
resourceId
result
PredictBandwidth Predict Bandwidth Utilization Percentage
Predict provisioned and consumed bandwidth. Provisioned bandwidth is the customer expected bandwidth set during the model deployment creation. Consumed bandwidth is the active bandwidth consumed by all ongoing predict requests for a specific model deployment OCID. This bandwidth is computed as current consumed bandwidth relative to the total provisioned load balancer bandwidth on every predict request.
resourceId
CpuUtilization CPU Utilization Percentage Activity level from the CPU.
resourceId
instanceId
MemoryUtilization Memory Utilization Percentage Memory in use.
resourceId
instanceId
NetworkBytes Network Receive and Transmit Bytes Bytes/sec Network receive and transmission throughput.
resourceId
instanceId
networkType
GPUCoreUtilization GPU Utilization Percentage Shows how busy the GPU devices are in a model deployment cluster.
resourceId
instanceId
GPUMemoryUtilization GPU Memory Utilization Percentage Shows the mean memory consumption of all GPU devices in a model deployment cluster.
resourceId
instanceId
Viewing Model Deployment Metrics
You can view the default metric charts using a model deployment details page in the Data Science service.
  1. From the model deployments page, select the name of the model deployment to view the metrics for. If you need help finding the list of model deployments, see Listing Model Deployments.
  2. Under Resources, select Metrics.
    The Metrics area displays a chart for each metric that's emitted to the metric namespace for Data Science.
For more information about the emitted metrics, see model deployment metrics.
If you don't see the metrics data for the model deployment session that you expect, see missing metrics data.
