Compare the model versions in Data Science based on the version information and the metadata.
Note
Only models associated with the same model version set can be compared.
On the Projects list page, select the project that contains the models that you want to work with. If you need help finding the list page or the project, see Listing Projects.
On the project details page, select Models.
All models in the selected project are displayed in a table, along with their model version sets.
Select the model version set.
Select Model memberships.
Select the checkbox next to each model version set to be compared.
Select Compare versions.
The Compare categories page opens. Select the tabs to compare different aspects of the model versions.
Use the lists to change the comparison.
Differences are highlighted by default. Select Highlight differences to remove the highlighting.
Select Close to return to the model version set details page.
