Creating and Saving a Model with the Console
Create a model in the Console and save it directly to the model catalog.
To document a model, you must prepare the metadata before you create and save it.
This task involves creating a model, adding metadata, defining the training environment, specifying predictions schemas, and saving the model to the model catalog.
Important
  • We recommend that you create and save models to the model catalog programmatically instead, either using ADS or the OCI Python SDK.
  • You can use ADS to create large models. Large models have artifacts limitations of up to 400 GB.
If you're saving a model trained elsewhere or want to use the Console, use these step to save a model:
  1. From the Data Science models page, create a model artifact zip archive on your local machine containing the score.py and runtime.yaml files (and any other files needed to run your model). Select Download sample artifact zip to get sample files that you can change to create your model artifact. If you need help finding the list of models, see Listing Models.
  2. Select Create model.
  3. Select the compartment to contain the model.
  4. (Optional) Enter a unique name (limit of 255 characters). If you don't provide a name, a name is automatically generated.
    For example, model20200108222435.
  5. (Optional) Enter a description (limit of 400 characters) for the model.
  6. Select one of Upload model artifact or Create model by reference.
  7. If in the step 6 you selected Upload model artifact, in the Upload model artifact box, select Select to upload the model artifact archive (a zip file).
    1. Drag the zip file into the Upload an artifact file box, and then select Upload.
  8. If in step 6 you selected Create model by reference:
    1. Select a compartment.
    2. Select a bucket.
    3. (Optional) Enter an object name prefix. The prefix must refer to the root directory of the model artifacts. It consists of all the artifacts related to the model, with score.py and runtime.yaml at the first level inside the prefix.
  9. (Optional) In the Model version set box, select Select, and then configure with an existing version set or create a new set.
  10. (Optional) In the Model provenance box, select Select.
    1. Select Notebook session or Job run depending on where you want to store the taxonomy documentation.
    2. Find the notebook session or job run that the model was trained with by using one of the following options:
      Select a project:
      Select the name of the project to use in the selected compartment.
      The selected compartment applies to both the project and the notebook session or job run, and both must be in the same compartment. If not, then use the OCID search instead.
      You can change the compartment for both the project and notebook session or job run.
      The name of the project to use in the selected compartment.
      Select the notebook session or job run that the model was trained with.
      OCID search:
      If the notebook session or job run is in a different compartment than the project, then enter the notebook session or job run OCID that you trained the model in.
    3. Select the notebook session or job run that the model was trained with.
    4. (Optional) Select Show advanced options to identify Git and model training information.
      Enter or select any of the following values:
      Git repository URL
      The URL of the remote Git repository.
      Git commit
      The commit ID of the Git repository.
      Git branch
      The name of the branch.
      Local model directory
      The directory path where the model artifact was temporarily stored. This could be a path in a notebook session or a local computer directory for example.
      Model training script
      The name of the Python script or notebook session that the model was trained with.
      Tip
      You can also populate model provenance metadata when you save a model to the model catalog using the OCI SDKs or the CLI.
    5. Select Select.
  11. (Optional) In the Model taxonomy box, select Select to specify what the model does, machine learning framework, hyperparameters, or to create custom metadata to document the model.
    Important
    The maximum allowed size for all the model metadata is 32000 bytes. The size is a combination of the preset model taxonomy and the custom attributes.
    1. In the Model taxonomy section, add preset labels as follows:
      Enter or select the following:
      Model taxonomy
      Use case
      The type of machine learning use case to use.
      Model framework
      The Python library you used to train the model.
      Model framework version
      The version of the machine learning framework. This is a free text value. For example, the value could be 2.3.
      Model algorithm or model estimator object
      The algorithm used or model instance class. This is a free text value. For example, sklearn.ensemble.RandomForestRegressor could be the value.
      Model hyperparameters
      The hyperparameters of the model in JSON format.
      Artifact test results
      The JSON output of the introspection test results run on the client side. These tests are included in the model artifact boilerplate code. You can run them optionally before saving the model in the model catalog.
      Create custom label and value attribute pairs
      Label
      The key label of the custom metadata
      Value
      The value attached to the key
      Category
      (Optional) The category of the metadata from many choices including:
      • performance
      • training profile
      • training and validation datasets
      • training environment
      • other
      You can use the category to group and filter custom metadata to display in the Console. This is useful when you have many custom metadata that you want to track.
      Description
      (Optional) Enter unique description of the custom metadata.
    2. (Optional) Add an artifact:
      1. Select the Metadata field name.
      2. Enter a value.
      3. (Optional) Enter search keywords to help find the artifact.
      4. To add another artifact, select +Add defined attribute and repeat the previous steps. You can repeat this step until you have 25 artifacts.
      Note
      You can only upload the artifact file when the model is created.
    3. Select Select.
  12. (Optional) Select Select in the Document model input and output data schema box to document the model predictions. You define model prediction features that the model requires to make a successful prediction. You also define input and output schemas that describe the predictions returned by the model (defined in the score.py file with the predict() function).
    Important
    The maximum allowed file size for the combined input and output schemas is 32000 bytes.
    1. Drag the input schema JSON file into the Upload an input schema box.
    2. Drag the output schema JSON file into the Upload an output schema box.
    3. Select Select.
    Important
    You can only document the input and output data schemas when you create the model. You can't edit the schemas post model creation.
  13. (Optional) Select Show Advanced Options to add tags.
  14. (Optional) In the Tags section, add one or more tags to the resourceType. If you have permissions to create a resource, then you also have permissions to apply free-form tags to that resource. To apply a defined tag, you must have permissions to use the tag namespace. For more information about tagging, see Resource Tags. If you're not sure whether to apply tags, skip this option or ask an administrator. You can apply tags later.
  15. SelectCreate.
    Note
    Models stored in the model catalog can also be deployed using model deployment.
