Creating a Maintenance Window
Create a maintenance window in Fleet Application Management. When you create a maintenance window, it's automatically assigned an active status.
The maintenance window is created and is listed on the Maintenance windows list page. Use the oci fleet-apps-management fleet-apps-management-maintenance-window maintenance-window create command and required parameters to create a maintenance window:
oci fleet-apps-management fleet-apps-management-maintenance-window maintenance-window create --compartment-id <compartment_OCID> --duration <number> --time-schedule-start <datetime> [OPTIONS]For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
Run the CreateMaintenanceWindow operation to create a maintenance window.
