Deleting a Maintenance Window
Delete a maintenance window in Fleet Application Management.
When you delete a maintenance window, all schedules associated with the maintenance window are also deleted. Deleting a maintenance window either deletes a maintenance window schedule or cancels jobs.
Important
You can't delete a maintenance window if a scheduled job associated with the maintenance window is in progress or is scheduled to run in the next 15 minutes.
- On the Maintenance windows list page, select the maintenance window that you want to work with. If you need help finding the list page or the maintenance window, see Listing Maintenance Windows.
- On the details page for the maintenance window, select Delete.
- In the Delete maintenance window dialog box, select Delete.
Use the oci fleet-apps-management fleet-apps-management-maintenance-window maintenance-window delete command and required parameters to delete a maintenance window:
oci fleet-apps-management fleet-apps-management-maintenance-window maintenance-window delete --maintenance-window-id <maintenance_window_OCID> [OPTIONS]For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
Run the DeleteMaintenanceWindow operation to delete a maintenance window.
