Adding Products
Add or remove products or product stacks from a fleet in Fleet Application Management.
    1. On the Fleets list page, select the fleet that you want to work with. If you need help finding the Fleets list page or a specific fleet, see Listing Fleets.
    2. On the fleet details page, select the Actions menu and then select Manage products.
    3. In the Manage products panel, select Add products.
    4. In the Add products panel, select the checkbox next to the product or product stack names you want to add and then select Add products.
      Use the Compartment filter to switch compartments to add products from a different compartment.
      Note
      Adding or removing a product or product stack starts the discovery process by confirming the targets, depending on whether auto confirmation of target resources is enabled.
      The selected products are added to the Manage products list table.
      Add more products or remove products, as required.
  • Use the oci fleet-apps-management fleet update command and required parameters to add product or product stacks to a fleet:
    oci fleet-apps-management fleet update --fleet-id <fleet_OCID> [OPTIONS]
    For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
  • Run the UpdateFleet operation to add product or product stacks to a fleet.
