Block-Volume
Using the Block-Volume subject area, you can create reports about the block volume resources.
These reports enable you to track the different attributes and metrics for block volume resources across tenancies and compartments.
Business Questions
The subject area can answer the following business questions:
  • What is the total number of backup counts for a block volume?
  • What is the total backup size for a block volume?
  • What is the total number of block volume count?
Logical Model
Fact table Block Volume connected to nine dimension tables, Subscription, Tenancy, Compartment, Date, Region, Availability Domain, Block Volume Combined, Block Volume Group, and Block Volume - Fact.
Metric Details
The fact folders in this subject area show the following metrics:
Metric Details for Block Volume
MetricDescription
Backup CountThis metric is calculated as the sum of total number of backups associated
Backup Size In GbsThis metric is calculated as the sum of size of backups in gigabytes.
Block Volume CountThis metric is calculated as the count of total records in Block Volume fact
Replica CountThis metric is calculated as the sum of total number of replicas
Volume Size In GbsThis metric is calculated as the sum of total size of the entity (volume or group) in gigabytes.
