About Vision Policies
Learn about Vision's resource policies including API permissions.
To control who has access to Vision and the type of access for each group of users, you must create policies. By default, only the users in the Administrators group have access to all Vision resources. For everyone else who's using the service, you must create policies that assign them proper rights to Vision resources. For a complete list of Oracle Cloud Infrastructure policies, see policy reference in the IAM with Identity Domains or the IAM without Identity Domains documentation.
Create all the policies at the root compartment level, that is, at the tenancy level. In your tenancy Console:
- Select Identity & Security.
- Select Policies.
- Select the root compartment.
Policy to Grant Users Access to Vision APIs
The policies at the root compartment level needed for Vision users.
allow group <group_in_tenancy> to use ai-service-vision-family in tenancyallow group <group_in_tenancy> to manage ai-service-vision-family in tenancyPolicy to Access Input Image Files in Object Storage
The policies required to access image files in Object Storage from Vision in the same tenancy or cross-tenancy.
- Same-tenancy Object Storage access
- If the input image is found in your tenancy's Object Storage, then create a group in the tenancy to
authorize the users who can access the Object Storage
there. Add the following policy in your tenancy at the root compartment level to grant
object storage USE permissions to the
group:
allow group <group_in_tenancy> to use object-family in tenancy - Cross-tenancy Object Storage access
- If the input image is found in tenancy_B object storage, and your user group in
tenancy_A, then you must define an ENDORSE READ policy on the user group in tenancy
A:
define tenancy <tenancy_B> as <tenancy_B_ocid> endorse group <group_in_tenancy_A> to read object in tenancy <tenancy_B>
Policy to Access Training Datasets in Object Storage
The policies required to access training datasets in Object Storage from Vision in the same tenancy or cross-tenancy.
- Same tenancy training dataset access
- If the customized training dataset is found in your tenancy's Object Storage, then create a group in the tenancy to
object storage USE permission to the
group:
allow group <group_in_tenancy> to use object-family in compartment <training-dataset-located-object-storage-compartment> - Cross-tenancy training dataset access
- If the customized training dataset is found in tenancy_B object store, and your user
group in tenancy_A, then you must define an ENDORSE READ policy on the user group in
tenancy
A:
Policy to Store Batch Processing Results in Object Storage
The policy required to store batch processing results in Object Storage from Vision.
allow group <group_in_tenancy> to manage object-family in compartment <batch_processing_results_located_object_storage_compartment>POST /actions/analyzeImage
The permission use ai-service-vision-analyze-image is required when
the request contains features with no modelId specified. That is, you're
referencing the pre-trained model.
If the request contains features with a modelId specified, that is you're
referencing a custom model, then the use ai-service-vision-model must be
granted to the user. The use ai-service-vision-analyze-image resource is part
of the ai-service-vision-family resource family.
/actions/analyzeImage request references a pre-trained model for
object detection, and references a custom model for image
classification:{
"features" : [
{ "featureType" : "OBJECT_DETECTION", "modelId" : "ocid1.aivisionmodel.etc..." },
{ "featureType": "IMAGE_CLASSIFICATION" }
"image" : { ... }
}use ai-service-vision-model and
use ai-service-vision-analyze-image permissions.Policy Examples
allow group <group_name> to use ai-service-vision-analyze-image in tenancyallow group <group_name> to use ai-service-vision-model in tenancyallow group <group_name> to use ai-service-vision-model in compartment <my_compartment>allow group <group_name> to use ai-service-vision-family in tenancyPOST /imageJobs
To schedule any image-related job, by calling /actions/ImageJobs, you
must have the use ai-service-vision-image-job permission.
If the job contains features referencing a custom modelId, then use
ai-service-vision-model must also be granted to the user. The
ai-service-vision-image-job resource is part of the
Policy Examples
allow group <group_name> to use ai-service-vision-analyze-image in tenancyallow group <group_name> to use ai-service-vision-model in tenancyallow group <group_name> to use ai-service-vision-model in compartment <compartment_name>allow group <group_name> to use ai-service-vision-family in compartment <compartment_name>
