Detecting Objects in an Image by Using a Batch Request
You can use the CLI, or API to call a model with a batch request.
  • Only PNG and JPEG format files are supported.
  • Each job can have no more than 2,000 images, or 500 KB in the body of the request.
More information on batch processing is available from the Batch Processing chapter.
  • This task isn't available in the Console.
  • Use the image-job command and required parameters to create an image processing batch job:
    oci ai-vision image-job create [OPTIONS]
    Use the analyze-image command and required parameters to detect object in the images:
    oci ai-vision analyze-image [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the CLI Command Reference.
  • Run the CreateImageJob operation to create a batch job to analyze images.
    Run the AnalyzeImage operation to detect the objects in the images.
