Terraform: Create a Kubernetes Cluster
In this tutorial, you use Terraform to set up a Kubernetes cluster in your Oracle Cloud Infrastructure account.
Key tasks include how to:
- Copy your existing scripts from the Terraform Get Started tutorials.
- Edit existing scripts for reuse.
- Write new scripts for a Kubernetes cluster.
![A diagram of the components needed to create a Kubernetes cluster with Terraform. From a local Linux environment, the user connects to an Oracle Cloud Infrastructure account and creates a cluster. The cluster creation includes creating network resources. The network resources include one private regional subnet for worker nodes. These nodes are compute nodes. There is also a public regional subnet created to use for load balancers. Each regional subnet spans three availability domains: AD1, AD2, and AD3. The public subnet is connected to the internet with a two-way arrow. The private subnet has two one-directional, outgoing arrows, one to the internet and the other to Oracle services network.](images/terraform-k8s-cluster.png)
For additional information, see:
Before You Begin
To successfully perform this tutorial, you must have the following:
- A paid Oracle Cloud Infrastructure account. See Signing Up for Oracle Cloud Infrastructure.
- A MacOS, Linux, or Windows computer.
- Terraform tutorial resources:
- Go through all the steps in:
- Keep the scripts you created in the
following directory:
$HOME/tf-simple-infrastructure/
1. Gather Required Information
Gather information for the compute instances in the node pool.
VM.Standard2.1
in the node pool..-
Save the
<node-shape>
,VM.Standard2.1
in your notepad. - Go to VM Standard Shapes to learn more about the shape.
2. Copy Existing Scripts
Copy the Terraform: Set Up a Simple Infrastructure tutorial scripts. Then, remove the scripts and outputs related to the compute instance. In the next section, you declare a node pool with compute instances.
3. Create Scripts
Create three scripts: one for a cluster, one for a node pool and one to print outputs.
- Go to Oracle Cloud Infrastructure Provider.
- In the left navigation Filter, enter
container engine
. - Under Container Engine, go to Resources and click oci_containerengine_cluster.
- Find the Resource Type from the title of the page:
- Type:
- Type:
- In the Argument Reference section, find all arguments
(inputs) labeled as (Required)
- compartment_id
- kubernetes_version
- name
- vcn_id
- Construct a resource block:
- Declare a resource block with the keyword:
resource
- Add a label for resource type:
"oci_containerengine_cluster"
- Add a label for a local name (your choice):
- The label can contain letters, digits, underscores (_), and hyphens (-). The first character must not be a digit.
- Example:
"oke-cluster"
- Inside the code block, provide a value for the required arguments.
They don't have a default value:
- compartment_id: Point to the compartment declared in
compartment.tf
:oci_identity_compartment.tf-compartment.id
- kubernetes_version: This tutorial uses version
v1.21.5
. You can check the Quick Create option in the Console for the latest version. - name: Assign a name of your choice.
- vcn_id: Point to the compartment declared in
vcn-module.tf
:module.vcn.vcn_id
- Provide values for the following optional arguments to override their
default values.
- add_ons: Assign
true
orfalse
for the following arguments:- is_kubernetes_dashboard_enabled
- is_tiller_enabled
- kubernetes_network_config: Assign a CIDR block as a
string for the following arguments:
pods_cidr
services_cidr
Note
The CIDR block for the pods must not overlap with the worker node and load balancer subnet CIDR blocks.
The CIDR block for the Kubernetes service must not overlap with the VCN CIDR block.
The example code in this tutorial uses the same CIDR blocks as the Quick Create option in the Console.
For more explanation, see CIDR Blocks and Container Engine for Kubernetes.
- service_lb_subnet_ids: Assign the public subnet you declared
in
public-subnet.tf
Note
The argument, service_lb_subnet_ids accepts a list of subnet ids:- Even if you have one subnet, use square brackets to denote a list.
- Example:
[oci_core_subnet.vcn-public-subnet.id]
- add_ons: Assign
container engine
. - Under Container Engine, go to Resources and click oci_containerengine_node_pool.
- Type:
- Type:
- cluster_id
- compartment_id
- name
- node_config_details
- placement_configs
- availability_domain
- subnet_id
- placement_configs
- node_shape
- node_source_details
- image_id
- source_type
resource
"oci_containerengine_node_pool"
Example:
"oke-node-pool"
Example:
- Inside the code block, provide a value for the required arguments:
- cluster_id: Point to the cluster declared in
cluster.tf
:oci_containerengine_cluster.oke-cluster.id
- compartment_id Point to the compartment declared in
compartment.tf
- kubernetes_version: This tutorial uses the same version as the Create Cluster wizard in the Console.
- name: Assign a name of your choice. The Create Cluster
wizard, uses the name
pool1
. - node_shape: Enter information you gathered in section one.
- node_source_details:
- image_id: Enter information you gathered in section one.
- source_type: Set to
"image"
default values.
- initial_node_labels: Assign key/value pairs for the nodes.
- key: Assign a key of your choice. The Console's
Quick Create option creates the key
"name"
. - value: Assign a value for the key. The Console's
Quick Create option assigns
"<your-cluster-name>"
to the"name"
key.
In this section, you declare outputs for the cluster and the node pool.
- For cluster outputs, refer to the Attribute Reference of the Resource: oci_containerengine_cluster page.
- For node pool outputs, refer to the Attribute Reference of the Resource: oci_containerengine_node_pool page.
Outputs for List Items
- Usually list attributes are plural: (end in s).
- List attribute example for Node Pool:
node_config_details
- To output all the attributes in a list, use the list attribute by itself, without any brackets.
- Example:
output "node-configuration-details"{ value = oci_containerengine_node_pool.oke-node-pool.node_config_details }
Sample output:
node-configuration-details = [ { "placement_configs" = [ { "availability_domain" = "QnsC:US-ASHBURN-AD-1" "subnet_id" = "ocid1.subnet.xxx" }, { "availability_domain" = "QnsC:US-ASHBURN-AD-2" "subnet_id" = "ocid1.subnet.xxx" }, { "availability_domain" = "QnsC:US-ASHBURN-AD-3" "subnet_id" = "ocid1.subnet.xxx" }, ] "size" = 3 }, ]
- To output or call an item from a list:
- Use the following
format:
<list-attribute-name>[index].<attribute-from-list>
- Replace
[index]
with:- [0] for the first item.
- [1] for the second item.
- [n] for the (n+1)th item.
- Use the following
format:
- Example:
Value for the
size
attribute:output "node-size" { value = oci_containerengine_node_pool.oke-node-pool.node_config_details[0].size }
4. Run Scripts
Run your Terraform scripts to create a compartment, a virtual cloud network, a Kubernetes cluster, and a node pool.
- Run your Terraform
scripts:
terraform apply
- When prompted for confirmation, enter
yes
, for your resources to be created. - It might take 15 minutes or more for the cluster to be created. After Terraform
creates the resources, review the output in the
terminal.
Apply complete! Resources: 14 added, 0 changed, 0 destroyed. Outputs: ... cluster-OCID = ocid1.cluster.xxx cluster-kubernetes-version = "v1.21.5" cluster-name = <your-cluster-name> cluster-state = ACTIVE ... node-pool-OCID = ocid1.nodepool.xxx node-pool-kubernetes-version = "v1.21.5" node-pool-name = "pool1" node-shape = "VM.Standard2.1" node-size = 3 ...
- 401 errors - (Service error:NotAuthenticated):
- You have an incorrect value for one of the following:
- tenancy OCID
- user OCID
- fingerprint
- RSA private key (the path or the key)
- no such host:
- You have an incorrect value for the following:
- region identifier
References:
What's Next
Congratulations! You have created a Kubernetes cluster using Terraform, in your Oracle Cloud Infrastructure account.
Now that you have a Kubernetes cluster, try the Kubernetes tutorials.
To explore more information about development with Oracle products, check out these sites:
