Terraform: Set Up OCI Terraform
In this tutorial, you set up Oracle Cloud Infrastructure Terraform provider scripts, documented in the Terraform Registry, to connect to your account. To confirm the setup, you fetch information from your tenancy.
Key tasks include how to:
- Create RSA keys.
- Set up Oracle Cloud Infrastructure Terraform provider scripts:
- Authenticate your Terraform scripts.
- Get information about the availability domains in your tenancy.
For additional information, see:
Before You Begin
To successfully perform this tutorial, you must have the following:
- An Oracle Cloud Infrastructure account. See Signing Up for Oracle Cloud Infrastructure.
- A MacOS, Linux, or Windows environment:
- MacOS
- Linux (Any distribution)
- You can install a Linux VM with an Always Free Compute shape, on Oracle Cloud Infrastructure:
- Oracle Cloud Infrastructure Cloud Shell:
- Windows Subsystem for Linux (WSL)
- Git for Windows to access a Linux VM.
1. Prepare
Prepare your environment for authenticating and running your Terraform scripts. Also, gather the information your account needs to authenticate the scripts.
Install the latest version of Terraform v1.1.3+:
If you created RSA keys for the Terraform Set Up Resource Discovery tutorial, then skip this step.
Create RSA keys for API signing into your Oracle Cloud Infrastructure account.
You have now set up the RSA keys to connect to your Oracle Cloud Infrastructure account.
Reference
If your username is in the Administrators group, then skip this section. Otherwise, have your administrator add the following policy to your tenancy:
allow group <the-group-your-username-belongs> to read all-resources in tenancy
With this privilege, you can list all the resources in your tenancy.
- In the top navigation bar, open the Profile menu.
- Click your username.
- In the left pane, click Groups.
- In a notepad, copy the Group Name that your username belongs.
- Open the navigation menu and click Identity & Security. Under Identity, click Policies.
- Select your compartment from the Compartment drop-down.
- Click Create Policy.
- Fill in the following information:
- Name:
list-resources
- Description:
Allow the group <the-group-your-username-belongs> to list the resources in this tenancy.
- Compartment:
<your-tenancy>(root)
- Name:
- For Policy Builder, click Show manual editor.
- Paste in the following
policy:
- Click Create.
Reference: Common Policies
Prepare the information you need to authenticate your Terraform scripts and copy them into your notepad.
2. Create Scripts
Create three scripts: one for authentication, one to fetch data from your account, and one to print outputs.
Use the following variables for API Key based authentication:
- tenancy_ocid
- user_ocid
- private_key_path
- fingerprint
- region
You do not need to install the provider. The provider is downloaded when you run the scripts in this tutorial.
In this section, you fetch a list of the availability domains in your tenancy.
By fetching data, you confirm that your OCI account authenticates your
provider.tf
script and you get information from your
account.
In Terraform, to fetch data, you use a data source. Fetching data from a data source is similar to the GET method in REST APIs.
- Go to Oracle Cloud Infrastructure Provider.
- In the left navigation Filter, enter
. - Under Identity, go to Data Sources and click oci_identity_availability_domains.
- Find the Resource Type from the title of the page:
- Type:
- Type:
- In the Argument Reference section, find all arguments (inputs) labeled as
(Required)
- compartment_id
- Construct a data source block:
- Declare a data source with the keyword:
data
. - Add a label for data source type:
"oci_identity_availability_domains"
- Add a label for a local name (your choice):
- The label can contain letters, digits, underscores (_), and hyphens (-). The first character must not be a digit.
- Example:
"ads"
- Inside the code block, provide values for all required arguments.
- Example:
compartment_id = "<some-compartment-ocid>"
- Example:
- For optional arguments, provide values to narrow down the fetch results. Only some data sources have optional arguments.
The data source oci_identity_availability_domains
, fetches a
list of availability domains. In this section, you declare an output
block to print the fetched information.
- On the Data Source: oci_identity_availability_domains
page, go to Attribute Reference.Note
Attributes are the outputs you can return for the oci_identity_availability_domains data source. - Find the attributes:
- Attribute: availability_domains:
- The list of availability domains
- If you output availability_domains, you get three
attributes for each availability domain in the list:
- compartment_id
- id
- name
- Construct a data source output block:
- Declare an output block with the keyword:
output
- Add a label to be printed with the output results:
- Example:
"all-availability-domains-in-your-tenancy"
- Inside the code block, enter a value for the data source output with
the expression:
value = data.<type>.<local-name-for-data-source>.<attribute>
- Example:
value = data.oci_identity_availability_domains.ads.availability_domains
3. Run Scripts
Run your Terraform scripts. After your account authenticates the scripts, Terraform fetches your tenancy's availability domains.
Congratulations! Your Oracle Cloud Infrastructure account can now authenticate your Oracle Cloud Infrastructure Terraform provider scripts.
References:
- 401 errors - (Service error:NotAuthenticated):
- You have an incorrect value for one of the following:
- tenancy OCID
- user OCID
- fingerprint
- RSA private key (the path or the key)
- no such host:
- You have an incorrect value for the following:
- region identifier
What's Next
For the next Terraform: Get Started tutorial, go to:
To explore more information about development with Oracle products, check out these sites:
