Managing Public DNS Zones
On a Roving Edge device, the Domain Name System (DNS) lets computers use hostnames instead of IP addresses to communicate with each other.
In its most basic form, DNS returns an IP address (if known) when given a string in the DNS namespace for that zone. However, DNS is also the way that an IP host client application knows where to get its own configuration information using DHCP (DHCID records), go to send or receive email (MX records), and more. Without DNS, client devices would have to know the proper IP addresses not only for local servers, but for every server or application they interacted with, no matter where in the world they were located. With DNS, clients can always find the correct location of www.oracle.com or any other application.
After you create a DNS zone inside a compartment, you can't move the zone to another compartment.
When creating a DNS zone, you specify the name of the domain it manages – for example: example.com. You select whether the zone is primary or secondary. A primary zone contains its own DNS records, while a secondary zone retrieves its records from another zone. To access the external zone's records, the secondary zone needs at least one server IP address for the external zone. In addition, a TSIG (Transaction Signature) key may be required. TSIG keys are shared secrets used for authentication of secondary DNS zones. You can store these keys in the compartment of your choice.
Each DNS zone you create automatically contains two essential records:
  • The SOA (Start of Authority) record specifies authoritative information about the DNS zone. This information includes the primary name server, the domain administrator email address, the domain serial number, and several timers related to refreshing the zone. For more information about SOA records, see RFC 1035.
  • The NS (Name Server) record lists the authoritative name servers for a zone. For more information about NS records, see RFC 1035.
You configure the DNS zone by adding specific domain information in the form of resource records. For example, using an address record, you make a domain name resolve to the public IP address of an instance in a public subnet of a VCN. For a list of record types, see Public DNS Resource Record Types.
