Network Gateway Example: Internet Gateway
VCNs are the basic networking unit of a Roving Edge device, and can communicate with other processes through various types of gateways used for a particular purpose.
In this example, access to a VCN from outside the rack is established through an Internet gateway (IGW). All steps to produce a working IGW are detailed.
This example sets up an IGW to allow access to web servers on a public IP subnet running inside an instance. It also adds an ingress rule to the default security list to allow outside access to the web servers on the public subnet. Then this example allows ingress connections for HTTPS connections on TCP port 443, the standard port for HTTP encrypted traffic.
Without this ingress rule, inbound HTTPS connections aren't allowed. Make the new rule stateful, which is the default and allows a reply to an HTTPS request without creating an explicit rule for responses.
Next, this example adds the existing IGW target to the route rules. The route rules are added to the default route table for the VCN, or a new route table created for reaching the IGW specifically. The route rule uses CIDR block 0.0.0.0/0. This means that all traffic not already covered by other rules in the route table goes to the IGW target specified in this new rule.
This example includes steps to enable or disable the IGW, and how to delete it.
Overview
There are three major operations for establishing and using an IGW. Each step has its own set of prerequisites and can usually be configured with the Device Console or the CLI.
The three activities used to configure and operate an IGW are:
  • Set up an IGW
  • Create or update a route table to include a rule for an IGW
  • Update the Security List or NSG
