Completing the Edge Peering Configuration
When two Roving Edge systems have correctly configured local endpoints, the peer connection can be created.
The peer connection is a symmetrical configuration, meaning the setup must be performed on each connected device. The administrators exchange the relevant configuration details of their system, so they can each include the peer details required for creating the connection. A trust relationship between the appliances is established through a CA chain stored in the Secret Service (Vault).
When the first device completes its side of the connection setup, it goes into a waiting state. By design, the device with the IP address ending with the lowest value initiates the connection. As soon as the entry for the peer device is detected, the CA certificates are verified and the mutual trust relationship is confirmed. After successful peering, a secure tunnel is established between the systems. It allows the administration services on the systems to exchange information with each other.
These parameters are required to create a peer connection:
  • the IP addresses of the remote endpoint for the tunnel
  • properties of the peer device: domain name, system name, serial number, ASN ID if applicable
  • properties of the peer Admin Service: host name, admin user name, admin password, CA chain
The network configuration must allow peer-to-peer connectivity between the replication endpoints, or use routable IPs when both systems are in separate address spaces. Ensure that the new network setup does not overlap with existing connections between the device and the data center.
Creating the Edge Peer Connection
When you have obtained all required parameters, create the peer connection.
  • Service CLI:
    Enter the following command on a single line, replacing the sample parameters with the ones you obtained:
    RED2-ADMIN> create edgePeerConnection \
    name=<peerconnection1> description=<"my peer connection"> \
    peerAdminHostname=<myred01.mydomain.com> peerSerialNumber=<1654BF2465> \
    peerAdminUserName=<admin> peerAdminPassword=<password> \
    peerSystemName=<myred01> peerDomainName=<mydomain.com> \
    peerReplicationIp=10.212.128.142 \
    peerAdminCaChain=<ca_string>
    Check the peer connection configuration using the following commands:
    RED2-ADMIN> list edgePeerConnection
    Data:
      id                                    Name              Peer Admin Hostname    Peer Rack Serial Number   Lifecycle State
      ocid1.drpeerconnection....unique_ID   peerconnection1   myred01.mydomain.com   1654BF2465                ACTIVE
    RED2-ADMIN> show peerConnection id=ocid1.drpeerconnection....unique_ID
    Data:
      Id = ocid1.drpeerconnection....unique_ID
      Type = EdgePeerConnection
      Lifecycle Sub State = ACTIVE
      Lifecycle State = ACTIVE
      Peer Rack Serial Number = 1654BF2465
      Peer Replication IP = 10.80.116.240
      Peer Admin CaChain = -----BEGIN CERTIFICATE-----\nMIIFbjCCA1agAwIBAgIQfMPkn17+ZTNl/jZjYzbpn[...]
      Peer Admin Hostname = myred01.mydomain.com
      Peer Rack Domain Name = mydomain.com
      Peer Rack System Name = myred01
      Last Updated Time = 2026-01-12T10:45:02Z
      Time Created = 2025-12-03T11:48:28Z
      Peer Rack Admin User Name = admin
      Peer Rack Admin User Password = *******
      ProgressRecordIds 1 = id:d39144d6-feef-4988-ba71-fac4b046fff8  type:ProgressRecord  name:
      ProgressRecordIds 2 = id:940b397f-993c-4ab9-9708-909dabb65c47  type:ProgressRecord  name:
      ProgressRecordIds 3 = id:64b31360-3d0d-4dc2-a925-35164143eb25  type:ProgressRecord  name:
      ProgressRecordIds 4 = id:7e8d9e2e-74b1-4d31-9098-7a09d719ec6a  type:ProgressRecord  name:
      ProgressRecordIds 5 = id:2309bcdc-1689-410b-a93e-528444ada2a5  type:ProgressRecord  name:
      ProgressRecordIds 6 = id:8a4d5747-d8fe-48e2-96e2-f4c797964cbe  type:ProgressRecord  name:
      Name = peerconnection1
      Work State = Normal
  • Service Web UI:
    Under Disaster Recovery Service, open the Edge Peer Connections page. In the top-right corner, click Create Peer Connection.
    In the pop-up window, enter all parameters in the respective fields. Click Create Peer Connection to apply the settings.
    In the Edge Peer Connections page, the table displays a new entry for the connection you created. Click the name in the table to display the detail page of the peer connection, and review its configuration parameters.
Updating the Edge Peer Connection
There is no CLI command or UI function to modify the peer connection once it's configured. Changing the peer connection requires that you delete it and create a new connection with the updated parameters.
However, you can perform an update on existing peer connections to accept a new CA chain from the peer system. A certificate change stops replication between the ZFS Storage Appliances, but the update command enables it again.
  • Service CLI:
    Look up the ID of the peer connection you need to update, then enter the update command as shown.
    Data:
    RED2-ADMIN> updateEdgePeerConnection id=ocid1.drpeerconnection....unique_ID
  • Service Web UI:
    Under Disaster Recovery Service, open the Edge Peer Connections page. In the table, click the name of the connection you need to update. The peer connection detail page is displayed. In the top-right corner, click Update.
Deleting the Edge Peer Connection
If a peer connection is no longer used, you can delete it. Ensure that the peer configuration is removed from each connected device.
  • Service CLI:
    Look up the ID of the peer connection you want to delete, then enter the delete command as shown.
    Data:
    RED2-ADMIN> delete edgePeerConnection id=ocid1.drpeerconnection....unique_ID
  • Service Web UI:
    Under Disaster Recovery Service, open the Edge Peer Connections page. In the table, click the name of the connection you want to delete. The peer connection detail page is displayed. In the top-right corner, click Delete.
