Deleting a Data Sync Task Definition
Learn how to delete a data sync task definition from a Roving Edge device.
- Sign in to the Roving Edge Device Console.
In the navigation menu, select Data Sync.
The Data Sync Tasks Definition page is displayed.
(Optional) Select a Status from the list to limit the data sync tasks displayed to that status.
Check the data sync tasks that you want to delete.
Select Actions menu (
) for the data sync task you checked and select Delete. -
Confirm the deletion when prompted.
