Getting Data Sync Task Details
Learn how to get the details of data sync tasks for Roving Edge devices.
Using the Device Console
- Sign in to the Roving Edge Device Console.
In the navigation menu, select Data Sync.
The Data Sync Task Definition page is displayed.
(Optional) Select a Status from the list to limit the data sync tasks displayed to that status.
Select Actions menu (
) for the data sync task whose details you want to get and select View Details. The task's Details page appears.
