Stopping a Data Sync Task
Learn how to stop a data sync task in progress for a Roving Edge device.
- Sign in to the Roving Edge Device Console.
In the navigation menu, select Data Sync.
The Data Sync Task Definition page is displayed.
(Optional) Select a Status from the list to limit the data sync tasks displayed to that status.
Check the data sync task that you want to stop.
Select Stop. Alternately, select Actions menu (
) for the data sync task that you checked and select Stop. -
Confirm the stop when prompted.
Note
You can only stop a data sync task that has already started.
