Setting Up Project Resource Management Security for E-Business Suite
Project Analytics supports security over following dimensions in Project Resource Management subject areas. In the Oracle BI Applications solution, the 'Business Unit' entity refers to 'Operating Unit Organizations' in E-Business Suite. The list of Business Units that a user has access to, is determined by E-Business Suite grants.
The following BI Duty Roles are applicable to the Project Resource Management subject area.
OBIA_EBS_PROJECT_EXECUTIVE_ANALYSIS_DUTY
OBIA_EBS_PROJECT_MANAGEMENT_ANALYSIS_DUTY
OBIA_EBS_PROJECT_DATA_SECURITY
These duty roles control the subject areas and dashboard content to which the user has access. Additionally, they ensure that the data security filters are applied to all the queries. To define new groups and mappings for users and BI roles, see How to Define New Groups and Mappings for Users and BI Roles.
| Project Resource Management Facts Securing Entity | Resource Availability | Resource Requirement | Resource Utilization Assignment | Resource Utilization Capacity | Resource Utilization Expected | Employee Job/Competency |
Project Business Unit |
N |
Y |
Y |
N |
Y |
N |
Project Organization |
N |
Y |
Y |
N |
Y |
N |
Expenditure Business Unit |
N |
N |
N |
N |
N |
N |
Contract Business Unit |
N |
N |
N |
N |
N |
N |
Project |
N |
Y |
Y |
N |
Y |
N |
Resource Organization |
N |
N |
N |
Y |
Y |
Y |
Ledger |
N |
N |
N |
N |
N |
N |
You must enable data security for Project Resource Management in E-Business Suite by enabling the initialization blocks listed below based on your E-Business Suite adaptor. Make sure that all Project Security initialization blocks for other adapters are disabled. If more than one source system is deployed then, you must also enable the initialization blocks of those source system.
Init Blocks for E-Business Suite R11x only:
Project Business Unit List RM EBS11x
Project Business Unit List RM EBSR12
Init Blocks for both E-Business Suite R11x and R12:
Project List RM EBS
Project Resource Organization List
On installation, initialization blocks are enabled for E-Business Suite R12. If you are deploying on a source system other than E-Business Suite R12, then you must enable the appropriate initialization blocks.
To apply data security filters, enable the appropriate initialization blocks depending on the deployed source system.
