About Working With Components in a Flow Chart
You can perform actions on the components in a flow chart, including expanding and collapsing components to show or hide detail, removing components, saving components as a template, copying and pasting components, and copying and pasting component groups and component references. You can also undo many of the changes you make to components while working with them in the Template Designer and Rule Designer flow charts.
