Entering Variable Values for a String Variable
A string variable can be a Oracle Hyperion Financial Management, Oracle Hyperion Planning, Oracle General Ledger, or Oracle Essbase replacement variable. A string variable can also be a Financial Management execution variable. A string variable must be alphanumeric and be no more than 255 characters. It can contain a null value, but cannot contain a leading & (ampersand) character in the value.
To enter values for a replacement string variable:
From Type, select String.
In the Value table, enter a value for the variable.
By default, RTP is selected. If you do not want to create a runtime prompt for this variable, clear RTP.
Planning users only
If you do not select RTP, you must enter a default value for the variable.
f you selected RTP, enter the runtime prompt text you want to display for users.
Planning and Essbase users only
Click
To enter values for a Financial Management replacement or execution string variable:
Enter a value, or click in the Value field to display the Actions icon.
Do one of these tasks:
To enter members, select Member. See Adding Members and Functions to a Component.
To enter functions, select Function. See Working with Functions.
Click
