Using System Templates
To use a system template, selected the template and drag it into a flow chart or script.
Related Topics
- Using the Clear Data Template
- Using the Copy Data Template
- Using the Amount-Unit-Rate Template
- Using the Allocate - Level to Level Template
- Using the Allocation Template
- Using the Aggregation Template
- Using the SET Commands Template
- Using the Currency Conversion Template
- Using the Export-Import Data Template
