Setting a Default Zoom Level
You can specify a default level for zooming operations. This setting applies to the Zoom In button and to double-click zooming if it is enabled (see Enabling Zoom on Double-Click).
To set a Zoom In default level:
  1. From the Smart View ribbon, select Options, and then select Member Options in the left panel.
  2. From the Zoom In Level drop-down menu, select one of the following levels:
    • Next Level to retrieve data for the children of the selected members
    • All Levels to retrieve data for all descendants of the selected members
    • Bottom Level to retrieve data for the lowest level of members in a dimension
    These Zoom In options are available for Oracle Essbase, Oracle Analytics Cloud - Essbase, and Oracle Enterprise Performance Management Cloud Standard-mode applications, such as Planning:
    • Same Level to retrieve data for all members at the same level as the selected member
    • Sibling Level to retrieve data for the siblings of the selected members
    • Same Generation to retrieve data for all members of the same generation as the selected members
    This Zoom In option is available for Essbase and Oracle Analytics Cloud - Essbase only:
    Formulas to retrieve data for all members that are defined by the formula of the selected member. The formula can be a member equation or a consolidation to the parent.
  3. Click OK.
